Results 1 to 11 of 11
    Default EVC BDM100 Original
    Hello All
    I have Original bdm100 to evc .
    This bdm , Read and writte only flash external or eporm external
    - I have soft bdm to go v. 1.810 , but only read and writte all , not possible , read or writte only flash external sample
    Please Help me
    Thanks.
    Jun 2009
    You must read it with WinOLS
    DK Veteran rsibiza's Avatar
    Unhappy
    But it doesnt work with cracked winols..i uses also original EVC BDM100 with BDMtoGo..not real good as you get a cripted file....
    Could be interestening how to get it working on cracked WinOls..or get WinOls 1.8 cracked..and working with it
    tehnosoftex's Avatar
    Romania
    Quote Originally Posted by rsibiza View Post
    But it work with cracked winols I have bdm100 original and I install the last bdmtogo software which install the drivers for bdmtogo. After that I open cracked winols and I have full control of bdm100. I can read write and save as bdmtogo or as binary.
    DK Veteran rappttor's Avatar
    PERPETUUM MOBILE
    that's a verry interesting news ....
    Quote Originally Posted by tehnosoftex View Post
    thats true ... but it depent on your firmware in the bdm100.
    I think, with newer firmware .. stop working !!
    Hello again.
    i install vinols 1.5 this page , and bdm original work fine , read ok,
    - Only have problem, thsi winols for me have problem checsum ..
    Have sample this error .
    he plugin OLS220_Bosch_V31.dll (03/10/2007) could not be loaded, since it uses an obsolete interface or is corrupted in general. Please update it.
    - its posible recalcualte checsum this crak version.
    thanks.
    Quote Originally Posted by masterb View Post
    I have old FW ON MY BDM100...its about 5 yeaes old now and as i am no official tuner EVC wont do update FW for me.
    I use also cracked winols but bdm never showed in hardware...:'(
    Romania
    Then try to install last bdmtogo software and try again with winols
    Unhappy
    I reinstalled mz windows XP system,and all soft on my pc...
    reinstalled WinOls running fine 1.5...
    reinstall your BDMtoGo posted...connect bdm to ecu...power up..
    In WinOls i can get data about serial number from BDM100...but still unable read or write flash or eprom...
