Results 1 to 7 of 7
    Jul 2009
    Default Help with Mercedes EZS/EIS Install
    Does anyone know the procedure In DAS/Xentry for fitting a new Mercedes EIS ignition switch using green workshop key.
    Member Gusk's Avatar
    Sep 2009
    GREECE
    Quote Originally Posted by BRAVO6 View Post
    Hi!! You must go with Xentry Das to EIS\EZS to initial startup and then you guided throu steps!!
    DK Veteran wsc's Avatar
    Aug 2009
    GR
    Quote Originally Posted by Gusk View Post
    welcome mate
    PS dwse ta fwta sou
    Smart car engineer ,
    Sep 2009
    GREECE
    Smile
    Quote Originally Posted by wsc View Post
    welcome mate
    PS dwse ta fwta sou
    Hello from DK for the present mate!!
    Jul 2009
    Thanks. Is there some way that I can know if the key that I have is okay. I only have one original key but dont want to mess up new EIS if the key transponder is faulty.
    Jul 2009
    Bump! Anyone any info on checking key transponder?
    Mar 2010
    if you go into Xentry Das to EIS/EZS dependent on the model there is usually a guided automated test for checking the key, it is preferable if you have two keys for a more reliable diagnosis but it is still possible with one
    this will depend on the version of DAS you are using and model but from memory it has been there for approx 2yrs for most models
    good luck
    regards
    Conect
