Results 1 to 7 of 7
    Default laguna glow plug light stuck on
    hi, i have a 2003 renault laguna 1.9 dci, when i start it up the glow plug light comes on 3 or 4 seconds after start up and stays on, car runs fine, changed the fuel filter and the light is still on, owners guide says there could be water content in the fuel filter or an electric fault?
    please what would be my next things to check?
    smirnoff_rules's Avatar
    Mar 2008
    birmingham
    its telling u theres a fault code in the ecu m8 , u need to read the code .. more that likely needs a glow plug changing , but being a Renault it could be anything
    Meat-Head's Avatar
    Quote Originally Posted by smirnoff_rules View Post
    Then after it has been plugged in, you will still be non the wiser.
    Meat-Head-Motors-Betting-Shop
    50:1 = Obscure unkown fault code
    100:1 = six different fault codes, all caused by each other
    20:1 = No faults stored
    15:1 = 2 faults you can't clear no matter what you do with it
    75:1 = 4 glowplugs faulty
    yes your right mate no error codes stored im ****ed , saw on one of your previous posts try swollowing a bag of resisters would this help?
    Meat-Head's Avatar
    pull the wire off each glow worm, feed via 20amp amp meter see what they suck
    use a reno software NOT eobd seting
    thanks for your help guys, there was 4 error codes, heater plug circuit, clutch contact signal, airflow sensor circuit, and turbo pressure sensor, replaced glow plugs, and turbo pressure sensor, clutch contact seen that on other lagunas with no light, so cleared codes and all good, thanks alot
    Meat-Head's Avatar
    i was close in the fact it was 4 faults
