Page 51 of 68 FirstFirst ... 41464748495051525354555661 ... LastLast
Results 751 to 765 of 1006
  1. #751
    drakov's Avatar
    Aug 2008
    I will call them on monday and ask price of new interface:-)
    Check out The Number 1 Resource for all Automotive Software with a lot of patience you like me will find what you need...
  2. #752
    skens's Avatar
    Mar 2010
    Zagreb,Croatia
    Default diabox
    hi
    i install,but i not registred
    please no . profile
    i try
    1FFFFFFF
    02FFFFFF
    00FFFFFF
    01FFFFFF
    where i mistake??
    diabox installed, activate the patch, activation diabox went in, watched the video!
    Step by step, but the number of profiles we do not receive
    thx
    Please dear members push the button thanks and reputation button(stars)
    do you need help? fill it in !!!
    Model:
    Motor capacity:
    Diesel/Gasoline:
    Production year:
    ECU type and number:
    Memories :
    https://www.digital-kaos.co.uk/forum...63#post1660863
  3. #753
    Oct 2008
    On Earth
    Quote Originally Posted by skens View Post
    hi
    please no . profile
    i try
    1FFFFFFF
    02FFFFFF
    00FFFFFF
    01FFFFFF
    where i mistake??
    thx
    Now becasue you ahve this issues ( I don't know what this means becasue you installed in other language then English and iI cannot figure it out what that menas ) you have to erase the APPDIAG file from C:/AWRoot/bin/fi
    The use Oatch
    Then activate again like this
    1234567
    12345678901234567890123456789012
    02FFFFFF
    And then you have to go to Configuration and write: adress, tel, and Zip Code
    And this is it
    Good luck
  4. #754
    skens's Avatar
    Mar 2010
    Zagreb,Croatia
    thx to reply
    I have not found APPDIAG file from C:/AWRoot/bin/fi!
    regards
    Model:
    Motor capacity:
    Diesel/Gasoline:
    Production year:
    Memories :
  5. #755
    Oct 2008
    On Earth
    thx to reply
    regards
    Well
    Install the DiagBox 6.01
    After it is installed, close it
    Then patch it and the run it and activate it
    Aftert this you can upgrade it
    Good luck
  6. #756
    skens's Avatar
    Mar 2010
    Zagreb,Croatia
    Default diag
    hi
    I have a clone! Scary 1 we noted that only can program SW5
    regards
    Model:
    Motor capacity:
    Diesel/Gasoline:
    Production year:
    Memories :
  7. #757
    Feb 2010
    hi
    please no . profile
    i try
    1FFFFFFF
    02FFFFFF
    00FFFFFF
    01FFFFFF
    where i mistake??
    thx
    Hello,
    I believe the error you receive is during initial installation, after setting the profile. I believe it says that "Lexia cannot be installed" or so. This error happens if you are installing DiagBox from HDD. You have to write a CD and run the installation from it, then everything will be OK (Lexia and PP2000) will install correctly.
    Check it and report back.
    Regards,
  8. #758
    skens's Avatar
    Mar 2010
    Zagreb,Croatia
    hi
    thx to reply
    the same is happening see att ! recorded on a CD and start the installation!
    diabox installed, activate the patch,delite psaagent in task manager!
    watched the video!http://www.digital-kaos.co.uk/forums...ternet-166586/
    Step by step,
    1234567
    02FFFFFF
    thx
    Model:
    Motor capacity:
    Diesel/Gasoline:
    Production year:
    Memories :
  9. #759
    Jul 2010
    Holland
    Little question...
    Is it possible to update to 6.19 from 6.05 using the file
    06.01->06.19 instead of every separate update till 6.19
    Or is the only fast way, again install 6.01 and update to latest.
    Best regards
    Rick
  10. #760
    scarymistake's Avatar
    Apr 2009
    Europe EN
    Quote Originally Posted by super-cab View Post
    Little question...
    Best regards
    Rick
    Yes no problem
  11. #761
    Feb 2010
    hi
    thx to reply
    Step by step,
    1234567
    02FFFFFF
    thx
    So, the steps are:
    1) Uninstall curent Diagbox and restart (be readedy for a FRESH installation);
    2) Burn the DiagBox installation kit onto a DVD (there is no need for an ISO, just burn the files);
    3) Install DiagBox FROM DVD and use (when asked) 32 characters code, followed by 02FFFFFF profile;
    4) According to these profile, the DiagBox will start installing first Lexia, then PP2000.
    I had the same problem and this was the solution.
    P.S. If you want to say "thanks", use dedicated button - don't thank me inside the message.
    Good luck,
  12. #762
    skens's Avatar
    Mar 2010
    Zagreb,Croatia
    Default dia
    hi
    the same is happening! recorded on a CD and started the installation on the computer with no installation Lexie PP2000
    regards
    Model:
    Motor capacity:
    Diesel/Gasoline:
    Production year:
    Memories :
  13. #763
    Apr 2009
    Europe EN
    hi
    regards
    Use a fresh install Win xp
    Copy the iso file DiagBox V6 to the pc
    Use a Iso program to mount the iso
    Install when he is asking to activate shut down DiagBox
    Use the patch and start up DB activate with the codes
    scary01
    02FFFFFF
    ready
    If not working PM and i look with teamviewer
    (only if you have put ultra-iso and the DB iso on it)
  14. #764
    Jul 2012
    France
    Default Arduino as flash spi programmer ?
    Scary,
    I have an Arduino on my desk. Could you think it is possible to use it as a SPI Flash programmer for the Winbond W25x80 ?
  15. #765
    Apr 2009
    Europe EN
    Quote Originally Posted by pipersw View Post
    Scary,
    I dont now but you need also program the inf. mcu
