Page 28 of 68 FirstFirst ... 18232425262728293031323338 ... LastLast
Results 406 to 420 of 1006
  1. #406
    matekhr's Avatar
    Croatia
    Quote Originally Posted by hornhunter View Post
    Can You please help me with installation of Diagbox, I start installation, after that I activate it successfully with patch but after all that when it finish installing PP2000 it says PPD error, I tried 3-4 times, every time the same error, does anybody knows what this is. Thanks....
    If you're talking about first time installation of v5.02, try to check your install disc. Some files might be corrupted.
    BTW, v5.02 MUST be installed from DVD, not from HDD.
  2. #407
    Member kalash's Avatar
    Oct 2010
    fr
    like, I just saw that v5.39 was m @ j "now" available at PSA! why go out after the v5.40 ?????????????
    I found the answer :
    CAUTION: Remove the version 5.40 DiagBox
    For your information, update 5.40 has been temporarily removed from the server since Saturday, 17/09 afternoon following the incident detection blockers.
    Therefore, the diag-box tools in version 5.37 or less will no longer be able to access to version 5.40. but the version 5.39
    here is the file of the m @ j v5.39 : http://www.megaupload.com/?d=9RLWU2Y0
  3. #408
    Jun 2009
    UK
    Guys, how to override this? Picture attached.
  4. #409
    Top Poster xilophene's Avatar
    Dec 2010
    hi
    this is normal, wrong profile! We need to profile as the installation 02FFFFFF by scarry.
  5. #410
    Oct 2010
    fr
    Quote Originally Posted by worldiagnostic View Post
    ON TEST : LB4C-HHFO-HAEN-IBG6
  6. #411
    Jun 2009
    UK
    Quote Originally Posted by kalash View Post
    One-time code won't help. We need just a working solution without this screen
  7. #412
    scarymistake's Avatar
    Apr 2009
    Europe EN
    First post update to V5.42
  8. #413
    drakov's Avatar
    Aug 2008
    The solution is use correct profile
    Check out The Number 1 Resource for all Automotive Software with a lot of patience you like me will find what you need...
  9. #414
    Member roby's Avatar
    May 2009
    Jupiter
    Quote Originally Posted by scarymistake View Post
    Hi scary,can you repack and reupload update 5.40->5.42 since Im getting crc error while opening or extracting it.
    Thanks.
  10. #415
    Apr 2009
    Europe EN
    Quote Originally Posted by roby View Post
    Thanks.
    OK.
    i have it see
  11. #416
    matekhr's Avatar
    Croatia
    The same problem with 5.37 -> 5.39
  12. #417
    Aug 2010
    Here i have the same problem with 5.37 to 5.39!
  13. #418
    Oct 2010
    fr
    ok, sorry and good luck
    cordially
  14. #419
    Apr 2009
    Europe EN
    Quote Originally Posted by matekhr View Post
    Ok sorry Problems with my upload.
    All links checked
    All ok now if not let me now
  15. #420
    DK Veteran tapiru's Avatar
    All links checked
    I downloaded yesterday night and seems now all are ok so thanks for your job
