excuse me the translation is no correct with google
@xilophene
i don't want to install windows xp just for 1 program, there must be some way to get it working on windows 7?
"I always tell the truth. Even when I lie"
"We Taking Over, One City At A Time"
probably, I did not seven! I'm not modern!
Update V05.10 only 140MB
Look at first post
look at the first post
http://www.digital-kaos.co.uk/forums...86/#post806086
Lexia/PP2000 and DiagBox update without internet
http://www.digital-kaos.co.uk/forums...ternet-155768/
hi
it' sV05.02 to V05.10 offline or on line v05.10
Hello guys
Have problem with DiagBox.After install and update to v05.10 I try a diagnose on Peugeot 206 1.4hdi.I use Lexia3 interface.
Mention : first time I diagnose the car with PP2000 and find the problem but with same cable and Diagbox sw I get nothing.
In attachment I post some screen shots from diagnostic session with DiagBox.
Please someone point me in the right direction : is needed a other Lexia cable to use with DiagBox and other to use with PP2000 or I did something wrong ?
First post updated V05.12
I think you chose the wrong program, you must use PP2000 (when there are three possibilities Diagtool, PP2000 planet and measure), because it is the program of diagnosis, rather diagtool is a (stupid) to help diagnose problems and Planet measure is the oscilloscope (if you have the interface).
I also think that you have chosen the wrong model 206 because if your car is a 1.4 hdi (8Hz) is definitely a 206 mux .
This is my first post on this forum, I always just read and sorry for my English. I installed v. 5.10 DiagBox and use Lexia on Citroen C5 2.2 hdi (2002) and almost everything works except telecodes. I choose to test global / BSI / telecode by manual / telecode by manual without data and choose the configuration. At this point we give a code passed by technical assistance. Question where to get this code?
Please help and thanks in advance for your support and understanding
I have a quick question,
I want to install diagbox on my system, (running windows XP) I have been using lexia3 and pps for many years now.
My question is: Is there an initial software version that I need to install and if so where can I find it??
Do I need to install the first ever released version and every superceded version from then on to have the full complete system or can I just install the latest version 5.12 ??
With the pps and lexia every update "dvd" could be installed without the need to install all the previous ones, is diagbox the same??
All help will be greatly appreciated!!
Many Thanks,
Install 5.02 (Base), activate or use patch, close program and run latest update, start diagbox and let updates install...... enjoy.
However I would advise you install DiagBox on fresh laptop so you always have old pps/lexia as backup.
Depending on activation method also defines if telecoding, key programming and configurations can be done.
Check out The Number 1 Resource for all Automotive Software with a lot of patience you like me will find what you need...
Thanks for the quick response,
I would like to activate with the telecoding, key programming and configurations capabilitys, Please can you advise how to do this, do you need to activate via a keygen for these capabilitys? is there a keygen availavble to support this yet??
Can someone please let me have the V05.02 software, (rapidshare links or similar etc).I tried to get it through the link earlier in the thread but without success so far.
Many Thanks,
