Page 57 of 59 FirstFirst ... 7475253545556575859 LastLast
Results 841 to 855 of 1006
Hybrid View
    Member dema2's Avatar
    italy
    Hi to all, i have a question, i have diagbox 7.30 installed and work very fine, i want to upgrade to 7.40, is it posible?, there is an update 7.30 to 7.40 of line, or i unistall all, and start new installation from 7.02 patched for to finish with 7,24 to 7,40 ?
    Thank to all, an advantage for any answer
    Dema2
    DK Veteran tapiru's Avatar
    Quote Originally Posted by dema2 View Post
    Dema2
    use 7.24 to 7.40 and you will be fine
  3. The Following User Says Thank You to tapiru For This Useful Post:
    xilophene (17th April, 2014)
    When I install Diagbox 7.40 on my Windows 7, 32 bit I can choose between Diagtool and PP2000. Does Diagtool work for my little bit older car Peugeot 406, 2004? Does it work with PP2000 in Diagbox?
    Feb 2014
    My clone Lexia3 from China can update it? i am worry about locked if update.....
    Jun 2012
    Anyone know why i get activation error (2) on initial install, diagbox 7.1 (chinese shitty clone) using software dvd via Alcohol iso mount, it installs, then always error, (2) to be clear usb lexia inserted or not ? internet on or off ? F**kin tools, never had such a nitemare loading sw, any pointers chaps sure its a schoolboy error on my part,,
    Going to try re installing clean, what sw can i use to ensure all files gone, as sure windows folders used on install, cc cleaner ok ??
    desperate as car in tomorrow, and need running Diagbox asap,,,
    Cheers
    LTU
    have you sorted your activation problem?
    If not, do you have .NET framework installed?
    No Signature
    LTU
    I have different problem, it installs, activated, sees the interface, and so on. Only after restart when it should become 7.02 it says wstransformer.exe error, installed the updates and so on, butnothing helps.
    I try to install on fresh isntall of windows XP SP3 on a virtual machine.
    Any help is appreaciated.
    Thanks.
    No Signature
    Sep 2010
    Quote Originally Posted by colouny View Post
    Thanks.
    You?ll need a virtual machine.
    DIAGBOX does?nt working corectly with WIN7.
  10. #9
    electronistul21's Avatar
    Nov 2011
    galati,romania
    internet on for activate ,but make manuel activation
    Carprog 8.21,xprog 5.55,galletto v54,kess and ktag rework
  11. #10
    peko's Avatar
    diagbox work like charme in win7 64 , but you can work just in CAN not k-line
  12. #11
    Member ECU2009's Avatar
    Jan 2016
    European Union
    guys please I need some information, I lexia 3 clone have a long time yet the version with two separate software Citroen and Peugeot, now I want to update it with diagbox with this current version, can I install it, or risk of lock ?? thanks in advance friends
    ECU2009
  13. #12
    BiH
    Interface checker
  14. #13
    Aug 2010
    Hi for all,
    I want update mi firm for Lexia 3 Clone
    What I need?
    Its is my Lexia 3
    Very Thanks!!!
  15. #14
    Jun 2017
    Netherlands
    Please also check the actual SN, it could be banned.
    Just download this zip and unpack into C:\APPLIC\LEXIA\MajAppCom
    https://mega.nz/#!sqQygKjC!SDeSPQ7oe...MD-LFgnDf_8UxA
  16. The Following 2 Users Say Thank You to micheldg For This Useful Post:
    Col19 (25th February, 2019), joe06 (10th February, 2019)
  17. #15
    Jun 2017
    Blackpool
    Default error 0
    Hope you can help me. I am trying to install diagbox V7.01 already patched on my Toshiba Satellite Pro running xp sp3 with netframework 3,5 sp1. every time i try i get activation error 0. i have tried the same software on a friend machine running windows 10 which worked straight away but i need XP to run other programs i have.
    any help would be great.
    Many thanks
    Pete
