Where I can find diagbox 5 ? Can someone can share the link ?
Hy all
i have an interface original PSA ( PPI)With serial not BLACK to list.
I look for installation direct V 7.15
Thank you
You can install the base 7.02 and then you can update to 7.15
What so hard?
Don't worry it isn't hard and dosen't takes many times
Good luck
Tanks
install the base 7.02 and update direct to 7.15?
Help needed! After closing the application (Diagbox 6.24) cannot open again, only after restarting computer. What can I do to solve this problem? thanks.
Uninstall it and install it back
In some computers ( only 32 bits ) the softwear it is working strange
Better is to make a new fresh windos installation and then install the Diagox adn see what happen
In my case in one Acee extensa it is working good but when i try to turn off the Diagbox it takes 10-12 minuets till it will turn off
So I'm using it in other computer. That's why i told you that it is working strange in some computers (because of the BIOS) I suppose so
Good luck
urzica (23rd September, 2013)
HI Friends I need Help
I need Patch for Diagbox v5.02
My Interface is Clone version V4.2.2 Actia 09.04.09 Serial 963830 B
Can I update for Biger version to 6,7 ???
No
The last version that you can use is Diagbox v5.29
Then if you want to have a tool working with all versions of Diagbox you need to flash it
Mr. Scarymistake will help you
Good luck
Thank ssss mattydr67
No
Good luck
I'm trying to fit an RD45 radio (RD4 with internal normade box, supports native USB and Bluetooth) on a Peugeot 307, I need to VIN code it, but up to the version 5.29 the Diagbox does not recognize it..
Can anyone please tell me which version can code this radio? Thanks!!!
- Salut
- saft FLASH MCU Programmer 16LX, for MB90Fxxx svp .
- merci d'avance
galmo I get a programator ge. papu the far fonctionnement
FlashKit29
Im having problems installing diagbox v5.02, I keep getting error 11 message. I was directed to this thread by scary mistake for help. Im not too sure of the instructions on the first thread. Can someone please explain in layman's terms how to install this software, i have clone interface....
