Page 8 of 68 FirstFirst ... 3456789101112131858 ... LastLast
Results 106 to 120 of 1006
  1. #106
    lee_hdi's Avatar
    Sheffield
    No link to the 5.21???
    You've linked to this - https://rapidshare.com/files/4538933...02_to_5.20.exe
  2. #107
    scarymistake's Avatar
    Apr 2009
    Europe EN
    first post update V05.02 TO V05.21
  3. #108
    Apr 2009
    Europe EN
    Quote Originally Posted by lee_hdi View Post
    sorry also updated in first post
  4. #109
    Apr 2009
    Europe EN
    First post updated V05.21 to V5.22
  5. #110
    diag box, version 5, using 21-key promotion and display a BSI exchange immo code keygen code before the device you want from me. What could be the problem
  6. #111
    Uploaded with ImageShack.us
    I need a help.
    BSI and the promotion of key
  7. #112
    lee_hdi's Avatar
    Sheffield
    Use the 2FFFFFF profile, and install from disc
  8. #113
    BL
    how i activate fully lexia and pp2000 after i activate diagbox i mean when i want to clear foults lexia ask me for codes provided by key generator no. 1.1.0.0 and look like this exmp.0gbd-56t8-345u-d48d
  9. #114
    Holland
    Just tried to update from v16 tot 22, using the 1 by 1 links
    Update from 05.16 -> 18 went well, activation accepted and program worked.
    Update from 18 -> 20 resultated in an "error" block in the screen of diagbox before I even could activate again...
    I removed all and hoped I could install 5.02 to start again with the 5.02->5.21 link...
    After installing 5.02 the patch gives "succesfull"
    Then I get an error with activation, I must reactivate to restart installation again.
    I tried different numbers and profiles. I cant get 5.02 working again.
    Does anyone has a tip for me???
    best regards, Rick
    v5.02 is running after removing a backup map
    update 02 to 21 is crassing for now, trying to found a solution for it
    Or I update to 05.20 first.
  10. #115
    Holland
    Quote Originally Posted by super-cab View Post
    installation update to 5.20 went OKE
    maybe tomorrow try to install the last two
    p.s. THANKS for all the files!!!!
  11. #116
    If anyone is having problems loading this prog to windows 7, you will.
    You can download windows xp mode and virtual pc from windows site and install diagbox to virtual xp in windows 7.
    Diagbox works perfectly!!!
    Hope this maybe of some help to someone!!!
  12. #117
    Default install problem
    hi can someone tell me what the problem is whit my install of diagbox 05.02 on windows 7 ultimate 86 i only get a smal part of the diagbox in the upper screen, i have tryed to install a new windows but to no help the computer is a lenovo 61 (orginal pps pc)
  13. #118
    lee_hdi's Avatar
    Sheffield
    Doesn't work on windows 7 as far as i know. Run Windows 8 in xp compatibility mode, and install it that way
  14. #119
    Quote Originally Posted by TOMMY1973 View Post
    uninstall diagbox/PPS from W7. Go to windows site and download this
    Windows XP Mode - Windows 7 features - Microsoft Windows
    Open your virtual PC/ XP Mode and install diagbox to this, connect PSA interface and attatch the usb port to XP mode , it will then load the drivers for the PSA Interface.
    Once youve got it up and running, shut it all down, reboot and you will see Virtual XP in your W7 programs, highlight it and you will see Diagbox (xp mode) there. Just click it and it will open perfectly for you!!!!!
  15. #120
    Apr 2009
    Europe EN
    Talking V5.23
    First post updated V05.23
  16. The Following User Says Thank You to scarymistake For This Useful Post:
    narudol (14th October, 2023)
