Page 65 of 68 FirstFirst ... 1555606162636465666768 LastLast
Results 961 to 975 of 1006
  1. #961
    ANDRADINA ---S?O PAULO---- BRASIL
    Scarymistake.
    My dear scary, please please help me.
    I use windows 7 ultimate system on my pc. I did all the updates perfectly to V7.27. But after upgrading to v7.27 Chinese clone my interface has stopped communicating with the car.
    After many attempts I decided to uninstall the software DIAGBOX.
    I used Revo uninstaller to uninstall. After that I restarted my pc and installed DIAGBOX V7.02.
    So I upgrade to V7.06 and now the software is just asking ACTIVATION. with this sentence:
    (you must enable applications to be able to use them at that time, will carry the activation of the equipment).
    Scarymistake, please help me.
    Or someone here from the DK has been there. already uninstalled and installed over 10 times and nothing.
  2. #962
    May 2012
    Poland
    Hi Scary ! You can price updates Lexia and address where you can send ? Reply to PM
  3. #963
    Mar 2010
    Hungary
    Hi friends,
    I changed my laptop. On my old laptop worked Pp2000 fine (win 7 - xp mode). Now i installed the pp2000 on the newer laptop and when i try work with car i get an error message (wincad error...win87em.dll-0001.02c6...).
    I tried to install diagbox 5.02 (on xp mode too), i can install and activate the program fine (5.02) //with 1234..12 and 2fffffff//, but i can't update it, the update program (5.02-5.20) run well, but when i start the diagbox and come the update screen then by end of procedure give fault and then the diagbox already can't run. I tried 5.02-5.03 update, but there is same problem.
    I have an clone interface.
    Can you help me with any good ideas?
    Thanks and HAPPY NEW YEAR!!!
    //Sorry for my bad english//
  4. #964
    Oct 2008
    diagbox use could help me with the original interface but does not connect with some cars for example peugeot hoggar any solution?
  5. #965
    Member dema2's Avatar
    italy
    Hi to all, i have a question, i have diagbox 7.30 installed and work very fine, i want to upgrade to 7.40, is it posible?, there is an update 7.30 to 7.40 of line, or i unistall all, and start new installation from 7.02 patched for to finish with 7,24 to 7,40 ?
    Thank to all, an advantage for any answer
    Dema2
  6. #966
    DK Veteran tapiru's Avatar
    Jan 2010
    Quote Originally Posted by dema2 View Post
    Dema2
    use 7.24 to 7.40 and you will be fine
  7. The Following User Says Thank You to tapiru For This Useful Post:
    xilophene (17th April, 2014)
  8. #967
    Jan 2010
    When I install Diagbox 7.40 on my Windows 7, 32 bit I can choose between Diagtool and PP2000. Does Diagtool work for my little bit older car Peugeot 406, 2004? Does it work with PP2000 in Diagbox?
  9. #968
    Feb 2014
    My clone Lexia3 from China can update it? i am worry about locked if update.....
  10. #969
    Jun 2012
    Anyone know why i get activation error (2) on initial install, diagbox 7.1 (chinese shitty clone) using software dvd via Alcohol iso mount, it installs, then always error, (2) to be clear usb lexia inserted or not ? internet on or off ? F**kin tools, never had such a nitemare loading sw, any pointers chaps sure its a schoolboy error on my part,,
    Going to try re installing clean, what sw can i use to ensure all files gone, as sure windows folders used on install, cc cleaner ok ??
    desperate as car in tomorrow, and need running Diagbox asap,,,
    Cheers
  11. #970
    Jan 2010
    LTU
    have you sorted your activation problem?
    If not, do you have .NET framework installed?
    No Signature
  12. #971
    Jan 2010
    LTU
    I have different problem, it installs, activated, sees the interface, and so on. Only after restart when it should become 7.02 it says wstransformer.exe error, installed the updates and so on, butnothing helps.
    I try to install on fresh isntall of windows XP SP3 on a virtual machine.
    Any help is appreaciated.
    Thanks.
    No Signature
  13. #972
    Sep 2010
    Quote Originally Posted by colouny View Post
    Thanks.
    You?ll need a virtual machine.
    DIAGBOX does?nt working corectly with WIN7.
  14. #973
    peko's Avatar
    Jan 2010
    diagbox work like charme in win7 64 , but you can work just in CAN not k-line
  15. #974
    Mar 2014
    Default diagbox 07.01
    how to enable diagbox thanx
  16. #975
    electronistul21's Avatar
    Nov 2011
    galati,romania
    internet on for activate ,but make manuel activation
    Carprog 8.21,xprog 5.55,galletto v54,kess and ktag rework
