I will call them on monday and ask price of new interface:-)
Check out The Number 1 Resource for all Automotive Software with a lot of patience you like me will find what you need...
hi
i install,but i not registred
please no . profile
i try
1FFFFFFF
02FFFFFF
00FFFFFF
01FFFFFF
where i mistake??
diabox installed, activate the patch, activation diabox went in, watched the video!
Step by step, but the number of profiles we do not receive
thx
Please dear members push the button thanks and reputation button(stars)
do you need help? fill it in !!!
Model:
Motor capacity:
Diesel/Gasoline:
Production year:
ECU type and number:
Memories :
https://www.digital-kaos.co.uk/forum...63#post1660863
Now becasue you ahve this issues ( I don't know what this means becasue you installed in other language then English and iI cannot figure it out what that menas ) you have to erase the APPDIAG file from C:/AWRoot/bin/fi
The use Oatch
Then activate again like this
1234567
12345678901234567890123456789012
02FFFFFF
And then you have to go to Configuration and write: adress, tel, and Zip Code
And this is it
Good luck
thx to reply
I have not found APPDIAG file from C:/AWRoot/bin/fi!
regards
Model:
Motor capacity:
Diesel/Gasoline:
Production year:
Memories :
hi
I have a clone! Scary 1 we noted that only can program SW5
regards
Model:
Motor capacity:
Diesel/Gasoline:
Production year:
Memories :
Hello,
I believe the error you receive is during initial installation, after setting the profile. I believe it says that "Lexia cannot be installed" or so. This error happens if you are installing DiagBox from HDD. You have to write a CD and run the installation from it, then everything will be OK (Lexia and PP2000) will install correctly.
Check it and report back.
Regards,
hi
thx to reply
the same is happening see att ! recorded on a CD and start the installation!
diabox installed, activate the patch,delite psaagent in task manager!
watched the video!http://www.digital-kaos.co.uk/forums...ternet-166586/
Step by step,
1234567
02FFFFFF
thx
Model:
Motor capacity:
Diesel/Gasoline:
Production year:
Memories :
Little question...
Is it possible to update to 6.19 from 6.05 using the file
06.01->06.19 instead of every separate update till 6.19
Or is the only fast way, again install 6.01 and update to latest.
Best regards
Rick
Lexia/PP2000 and DiagBox update without internet
http://www.digital-kaos.co.uk/forums...ternet-155768/
http://www.digital-kaos.co.uk/forums...86/#post806086
So, the steps are:
1) Uninstall curent Diagbox and restart (be readedy for a FRESH installation);
2) Burn the DiagBox installation kit onto a DVD (there is no need for an ISO, just burn the files);
3) Install DiagBox FROM DVD and use (when asked) 32 characters code, followed by 02FFFFFF profile;
4) According to these profile, the DiagBox will start installing first Lexia, then PP2000.
I had the same problem and this was the solution.
P.S. If you want to say "thanks", use dedicated button - don't thank me inside the message.
Good luck,
hi
the same is happening! recorded on a CD and started the installation on the computer with no installation Lexie PP2000
regards
Model:
Motor capacity:
Diesel/Gasoline:
Production year:
Memories :
Use a fresh install Win xp
Copy the iso file DiagBox V6 to the pc
Use a Iso program to mount the iso
Install when he is asking to activate shut down DiagBox
Use the patch and start up DB activate with the codes
scary01
02FFFFFF
ready
If not working PM and i look with teamviewer
(only if you have put ultra-iso and the DB iso on it)
Scary,
I have an Arduino on my desk. Could you think it is possible to use it as a SPI Flash programmer for the Winbond W25x80 ?
