I just received interface and installed DiagBox v6.01. However, it does not communicate with ANY ecu in the car. I tested on C8, Xsara Picasso and P307. "No communication during initialization" ... what could be wrong?
Lexia/PP2000 and DiagBox update without internet
http://www.digital-kaos.co.uk/forums...ternet-155768/
http://www.digital-kaos.co.uk/forums...86/#post806086
I have a reflashed clone and mine it works great in all cars.
Today I tested in Peugeot 307 2002 and Jumper III 2008 ( using adaptor )
I had no car that I couldn't tested.
But I have Diagbox v6.28 ( till v6.24 I use Mr. Scary's offline update then till he shared the v6.01 to 6.28 I used the online update and Mr. Debutant patch ) and reflashed tool as well and it's working like a charm
Good luck and many thanks allways for his great job
Correction: Works, but only communicates with BSI.
@Scarymistake: Is this because the interface is not reflashed?
^ not interface problem. OBD and cabel problem. Turn hand to obd/cable right side/down and start test again.
i get "WSTransformer.exe" error when diagbox start !
i use the last pre-actived version diagbox 6.01 !
same error for you with pre-actived version ?
First post update to V6.30
hi. i have problem with instalation diagbox 6.01. same error. (new windows xp sp3 installed and error ((
the installation has been completed, the program will start automatically, and i have error mesage
what is wrong?
I helped you, press thanks button
Hi all.I have a problem. Win 7 Professional evolition XS does not recognize the interface, it can not find a driver. Can anyone help?
First of all I think many say do not work good on win7.
Drivers shoud install automaticly if all ok whit hardware.
Maybe your lexia is not ok,I mean multiplexer.
Is your windows maybe 64bit,you shoud than try manualy to install drivers,but again,I recomend win xp or atleast virtual one.
Hi guys
I can use that version DIAGBOX
thank you very much
