Page 4 of 7 FirstFirst 1234567 LastLast
Results 46 to 60 of 102
  1. #46
    I understand. But, the problem is that with fuse like in document the vcds don't work. if i don't write the fuses, vcds work fine. (for this i must erase atmega with ponyprog and set ALL fuses and bits unactivated in ponyprog).
  2. #47
    DK Veteran rsibiza's Avatar
    Wink
    For me works just fine,but no problem.
    Write fuse and lockbits with pony,so your interface will work,then read fuse and lockbits with khazama or extremeburner save them and all will be fine.
    Anyway i also encoured some errors last time...using khazama,and now i use more extremeburner...lot more reliable i think,but not write all...khazama and extremeburner work better if first write only fuse/lockbits then flash and last eprom one by one...
    If i choose write all i get errors also...
  3. #48
    Aug 2010
    Hola! gracias por el dato, voy a probar y les cuento!
  4. #49
    Quote Originally Posted by rsibiza View Post
    Well, with pony i write flash and eeprom and the last, fuses and bits. never errors. with kazama and extremeburner, without fuses and bits, ok, with them, not ok.
  5. #50
    Strange....mhhhh
  6. #51
    I'll try to transform the bits of ponyprog in hex and write with extreme burner. I hope to not block another ATMEGA....But... extreme burner have one textbox Calibration". In ponyprog is'nt. Must use your "FFFFFF56"?
  7. #52
    Dt remeber56 or 58
    Try write fuses by pony and read with extremeburn...you will have the right one
  8. #53
    Oct 2008
    On Earth
    @liviudiaconu
    m8 don't waist your time. use what you know better, i mean use ponyprog and forget about other programmer.
    you know and you write Atmega's with it ok, and with the USB programmer you bloked an Atmega so till have a High voltage programmer to try please don't waist your time ask here. No one will answear you the right way.
    Ok you can do like rsibiza said but forget about that.
    The short way is the way you know not the stright ahead way.
    You know what I mean.
    Good luck
  9. #54
    ok, i understand. ponyprog use lpt (to me on the notebook without com or lpt native=lpt programmer+pcmcia/lpt). usb programmer ib little and not need nothing else
  10. #55
    Member carstar24's Avatar
    ...this thread is very interesting...i just ordered the fischl programmer and a vcds clone for experiment
  11. #56
    DK Veteran elchip's Avatar
    EU
    Post Info
    Original device can be flashed by USB.
    Cloned device must be flashed by ltp or usb avr programmer.
    Original tool's have bootloader inside..
    That is why you update - flash via serial port ...
    And AVR can be readed if they lock 100% , little harder then PicMicro but can noninvasive with programmer modified for that need's....
    Regard's
    [I]Automotive Electronics Solutions
    Mercedes-Benz Reverse Development Engineer ...
    Mercedes CFF 2010-2017 CFF all models all modules
    Vediamo help flashing over teamviewer ...
    JLR SDD online + offline ...last official ...
  12. #57
    tehnosoftex's Avatar
    Romania
    Quote Originally Posted by elchip View Post
    Regard's
    Can you give some directions how to do that? In which way to modify the programmer? It need to modify vcc , frequency or both?
  13. #58
    Jan 2011
    Hello peoplee, need German Dump for 10.6 - 10.61 or whatever
    Pls. send me MSG
    Brauche Deutsche Version Dump 10.6 - 10.61
    Bitte um Hilfe ?ber priv MSG
    Danke
  14. #59
    Quote Originally Posted by lega77 View Post
    Pls. send me MSG
    Danke
    Youre kidding i suppose...10.6 german...
    The 10.6 in english isnt completely avaible for free...only flash...swimsnaround for free..but no eprom...
    Good luck
  15. #60
    Jan 2011
    where i can find some dumps? Version doesnt matter, just for playing
