Page 5 of 7 FirstFirst 1234567 LastLast
Results 61 to 75 of 102
  1. #61
    DK Veteran rsibiza's Avatar
    Wink
    Quote Originally Posted by ReDOOM View Post
    where i can find some dumps? Version doesnt matter, just for playing
    My Friend.
    Welcome to DK.
    Just swap to introduce yourself,do it.
    After this step use search button and type vcds enter...in between lot of usefull threats and non sense bull...t you will find some flash and eprom dumps for vcds..maybee the working installer too...
    Best regards.
  2. #62
    Jan 2011
    Constanta, Romania
    hello, I founded on the net that for updating a colned vagcom, it is necessary to update atmega 162 and 93c46, but on my cloned interface there is no IC labeled 93c46...
  3. #63
    Quote Originally Posted by doni1 View Post
    You have crappy china clone with ftdi xxrl in place of xxbl.
    The rl one have eprom inside ftdi chip...
    Need more solder works redump gal16v solder wires from gal to ftdi etc...
    Normally need also take off the stc chip...this recovers or crashes the atmega162...
  4. #64
    DK Veteran bibkare's Avatar
    B & H
    Hi RSIbiza mate, i was under impression that since changes in garage section you are not with us anymore like you used to, just want to say i am glad to read your posts again and learn new things for sure.
    best regards
  5. #65
    B & H
    I understand. But, the problem is that with fuse like in document the vcds don't work. if i don't write the fuses, vcds work fine. (for this i must erase atmega with ponyprog and set ALL fuses and bits unactivated in ponyprog).
    Maybe you have too fast PC, for ponyprog best results are P3 and lower, i had a lot of trouble with faster PC-s
  6. #66
    Quote Originally Posted by bibkare View Post
    best regards
    Hi Bibkare.
    No have nothing to do with changes in garage
    I just actually have to finish some work before 06.2011...lot of work...
    Thats why...
    All i knew about vcds i think i have write about...but if i can help...
  7. #67
    Oct 2008
    On Earth
    No my friend, let me show how the things works.
    liviudiaconu asked rsibiza how he can set the security bits in Khazama programmer or in the Extremeburner programmer becasue he use an USB programmer for Atmega162.
    In tthe rsibiza tutorial about how to programm atmega with this kind of programmer using that two softwear, he set the security bits in a way but if you want to read then the atmega you can.
    Now it is not a problem liviudiaconu fix that incovenience by himself. Not problem now.
    I understand rsibiza why he is just half with us and please my friend don't complain about him because he had and he still has a good contribution in this forum.
    It was a confusion and now everything is fine. rsibiza didn't tell him how to set the security bits but this was a usefull because he make us to think and sometimes when u use your brain you can fix everything.
    So good luck guys and thanks to you my friend bibkare and also thanks to you rsibiza for your contribution in this forum.
  8. #68
    Member basco's Avatar
    LONDON
    i've been trying to reflash my vcds 805 atmega chip for a while now with no success so i have just given up i also have fried my 704 interface as well so enough of this is what i say im now going to buy the damn original from rosstech !!!!!!
  9. #69
    Wink
    Quote Originally Posted by basco View Post
    I am sorry for u,that i wonted work...
    But ori one is fine...u will have live long free updates
  10. #70
    Mar 2011
    i am new on this forum.
    i have vcds 908.0 with vag908 cable.
    i tried to update the software but my cable doesn't work anymore on my car.
    the software doesn't start on windows (vcds908) and if i try to launch vcds 10.6 it said that the controller is present but when i plug it to my car , it said it is not present !!
    i am "lost" , i read a lot in this forum and i think that my cable is "dead" .
    In several topic i read that i can try to reprogramm the atmega 162 and may be make my cable work .
    does somebody can help me ?
    another thing : i can't download attachement files in this forum , why ?
    thank you very much for your help.
  11. #71
    Wink
    Quote Originally Posted by saturn0008 View Post
    U have lot of time to learn,so read carefully the forum rules,and you will have half of job,then introduce yourself,as u can read in rules..and then start over
    Best regards.
    The answer starts with post nr 1 here..dont u think?
  12. #72
    Mar 2011
    hi
    im new here
    i need a instruction to dump a chinaclone fron 805 to 908.
    can you help me please?
  13. #73
    DK Veteran mishu_b's Avatar
    Land of Choice!
    Quote Originally Posted by noelmarlon View Post
    hi
    im new here
    Hi and welcome!
    you have here all you need: http://www.digital-kaos.co.uk/forums...rything-99750/
    atb
  14. #74
    Mar 2011
    Hello to everybody. I "burned" my 805 cable by Internet access so I find solution for repair that. I tryed with solutions from this site but when I try to download enything I receive the nessage "not have permission to access...". I am allready registered. Can anybody help me to repair my 805 cable, please?
    With respect,
    Alexander
  15. #75
    Dec 2010
    Hi, I've got the China clone of VCDS 10.6.2. It works incorrect. It doesn't show right codes, the basic settings are not right and so on. The FirmWare is 1.83. Does anybody have the same problem?
