Page 2 of 8 FirstFirst 1234567 ... LastLast
Results 16 to 30 of 115
  1. #16
    I have a unit that was not blacklisted,but I do not know how to read serial number,Can you send me screenshot it?
  2. #17
    try to finde it out from the starutility
  3. #18
    Quote Originally Posted by duguqiubai View Post
    Run the Caesar test from Star utilities (you may need to use the copy from the WINNT folder or some other place). Caesar test reads the serial number.
    Do not post it on the forum, better to leave it for PM.
  4. #19
    DK Veteran gmatj's Avatar
    Heaven (is place on earth)
    Quote Originally Posted by fanrong View Post
    2010.7 Xentry Fault (1.17)-7.870 ;(2.27_-7.870 error fix
    help!!!
    HAve a look here : http://www.digital-kaos.co.uk/forums...43/#post792448
    And use Search button - It does wonders !!
  5. #20
    need 2010.7 Xentry Fault (1.17)-7.870 ;(2.27)-7.870 error fix
    used clone star
  6. #21
    Sep 2010
    870 is a blocked mux. the old fixes do not work.
    the programing has changed in xentry to block the multiplexers on the blacklist.
    Only one place has the fix for this as far as I am aware, and they cannot be named here
  7. #22
    870 error already fix, anyone want to fix. pls contact me
  8. #23
    Quote Originally Posted by littledan91 View Post
    You can tell us. The file path and file name?
  9. #24
    Quote Originally Posted by kentzee View Post
    Can you tell me repair 870
  10. #25
    Can you tell me repair 870?
  11. #26
    antonypaul's Avatar
    Smile
    Quote Originally Posted by gmatj View Post
    Dear M8,
    NO access Authorization code please contact the Star diagnosis Call center kindly do Any solution for this Thanks In Advance
    Antony
  12. #27
    i think your registry is compact 2, need to change to compact 4
  13. #28
    Sep 2010
    I dont know what the new solution is, i dont have it. but I do know the old fix does not work with xentry
  14. #29
    impactops's Avatar
    Rename the original DAS32R2.exe *.bak then copy the one in the archive to C:\Programme\DAS\Bin
    Give this a go & see what happens, i'm not promissing anything
    Impactops
  15. #30
    Quote Originally Posted by impactops View Post
    Impactops
    I should have tried this instead of asking but it is too late now, so: is this really supposed to fix the Xentry 870 error? I cannot see how changing the DAS32R2.exe would make Xentry behave differently.
    I thought this thread was about the Xentry 870, many of us are able to run DAS perfectly fine but Xentry with new cars (real diagnosis, not simulation) returns this (1.17)-7.870 error.
