Page 7 of 8 FirstFirst ... 2345678 LastLast
Results 91 to 105 of 115
  1. #91
    Quote Originally Posted by davor.electronic View Post
    hi,
    i change the this file and i still get (1.17)-7.870 and (2.27)-7.870 error in xentry .....
    please help me
    Which file did you change it with? The thread had at least two files, one good and one did not work.
  2. #92
    Quote Originally Posted by DB_member View Post
    i'm try all 2 files ....
  3. #93
    hallo
    i have a problem. i changed language English -> Germany. Xentry say ''Restart Xentry''
    erro at starting program : Internal error (2.75)-3.175
    Xentry/DAS 9.2010
  4. #94
    can anyone help please ????
    i try solution from some post but for me not work ... please help
  5. #95
    DK Veteran Larue's Avatar
    Somerset, UK
    Hmmm....You are asking for help and not helping DB_member to help You! What exactly files You have changed? Where?
  6. #96
    Quote Originally Posted by mafiacccp View Post
    hallo
    Xentry/DAS 9.2010
    solution is here on forum..just do a search
  7. #97
    Quote Originally Posted by Larue View Post
    hi,
    i change the cal files from next 2 post :
    http://www.digital-kaos.co.uk/forums...89/index4.html
    and still i have same problem
    please can you help me ?
  8. #98
    hi,
    You should use the second file from this link. Where did you put the file?
  9. #99
    i solved the problem , thank you very much for help
    davor
  10. #100
    hi
    HHTwin internl fault 10752
    HHTwin doesn't start
  11. #101
    hi
    did you check hht.ini file in c:\windows?
  12. #102
    what I must look!?
    i have xentry 8.2010.
  13. #103
    put your hht.ini here
  14. #104
    Quote Originally Posted by rocris View Post
    [STARTUP]
    DX=515
    DY=510
    X=110
    Y=0
    BACK=21
    SLAVE=PARTT2
    DEBOUT=1
    DEBLVL=6
    SPC=02
    SPCN=02
    SPCP=02
    SPCD=02
    SPCV=02
    [STARCONF]
    BMPPATH=C:\USERDATA\HHTFiles\
    MAXFILES=200
    DEBOUT=1
    DEBLVL=6
  15. #105
    DK Veteran cocutanu's Avatar
    Jun 2009
    Edit this line with notepad and save the new file keeping the same extension ".ini" :
    Instead of "SLAVE=PARTT2" edit to "SLAVE=PARTD2"
    And make sure your Star system is using COM2 port for communication.
    Good Luck
