Page 8 of 8 FirstFirst ... 345678
Results 106 to 115 of 115
  1. #106
    Quote Originally Posted by cocutanu View Post
    Edit this line with notepad and save the new file keeping the same extension ".ini" :
    Instead of "SLAVE=PARTT2" edit to "SLAVE=PARTD2"
    And make sure your Star system is using COM2 port for communication.
    Good Luck
    I have not had problems with the original setting "T2" with my multiplexer although I don't use it often with HHT and have tried it with a limited number of HHT cars only.
  2. #107
    Quote Originally Posted by mafiacccp View Post
    [STARTUP]
    DX=515
    DY=510
    X=110
    Y=0
    BACK=21
    SLAVE=PARTT2
    DEBOUT=1
    DEBLVL=6
    SPC=02
    SPCN=02
    SPCP=02
    SPCD=02
    SPCV=02
    [STARCONF]
    BMPPATH=C:\USERDATA\HHTFiles\
    MAXFILES=200
    DEBOUT=1
    DEBLVL=6
    cocutanu already posted solution...
  3. #108
    Any idea about this error?
    Take a look at the pic
    data sectors incomplete
  4. #109
    Quote Originally Posted by djlight View Post
    install xentry again...
  5. #110
    on original star diagnosis
    i tried to do the up date for 1 2011 again and i made the date for the star is 17/2/2011
    but after installing the CD
    the xentry didn't installed and the App-ID 250
    so that i can't save the license for that
    any help please??
  6. #111
    i got this message for my original star diagnosis
    ave not succesfully
    liccheck license xentry diagnosis
    4-startkey can not be decoded or scheme is not recognized or app id unknow
    my app id 250
    hw Id-10ebfa1512de
  7. #112
    Turkmenistan
    Hello.
    Any idea about this error? Das works, Xentry not. Xentry reinstalled many times, all time have this problem. Changing the key does not help. What may help me?
  8. #113
    Quote Originally Posted by Amirziy View Post
    Hello.
    Sounds like you did not save your Xentry licence correctly after all.
  9. #114
    Aug 2022
    Добрый день.подскажите а где можна скачать cal.sli???спасибо
  10. #115
    Aug 2022
    Quote Originally Posted by impactops View Post
    Try this people,
    copy the cal.sli out of the rar file into F:\Programme\Xentry\bin\llist
    Rename the original first!
    What ever you do make sure you have a cal.sli file in that directory before you run xentry, if you run xentry and you dont it deletes another file then you have a different error 175.
    Impactops
    Everybody talks in riddles,
    Let me ask you guys one basic simple question.
    These interfaces that get this so called 870 Blacklist error in Xentry for 9.2010, Did the error occur for DAS aswell & a fix was applied or did DAS work without any file mods/fixes applied
    Impactops
    Добрый день с где можна скачать cal.sli?
