Results 1 to 11 of 11
    Sep 2010
    Naas
    Default classical mini cooper 99 srs problem
    Hi guys,
    I have problem with classic mini 99. Srs light is going on after 1 or 2 min. somebody had this problem before? what diag tool is good for this car, because I used launch, cdif and cant connect to srs.
    tomtom0785's Avatar
    Austria
    aybe it has flashing code via SRS Light??
    but i don't know exactly and can't find something about - sorry
    enjoy and have Fun
    Tom
    Meat-Head's Avatar
    Does the horn work when the light is on?
    Try a resistor across the airbag squib and see what happens
    z786's Avatar
    10 Steps Ahead of You
    plugs under seats, unplug, clean, plug back in
    "I always tell the truth. Even when I lie"
    "We Taking Over, One City At A Time"
    Meat-Head's Avatar
    Quote Originally Posted by z786 View Post
    If i was you either edit that post, or pretend you are replying to another.
    *THINK* you will find they have the detonators in the rear 'bins'
    Nothing under the seats
    Sep 2010
    Naas
    I think somebody left open window and floor is really wet. what I did for test:
    -replace airbag to resistor,
    - I check ground an power.
    Can I replace detonators to resistors as well?
    launch is working with mini?
    Fordracer4life's Avatar
    under the sea
    Quote Originally Posted by msienicki View Post
    I use 2 ohm resistors to test pretensioner detenators all the time. I also use stabilant 22 on all air bag connectors and it fixes a lot of high resistance codes.
    Meat-Head's Avatar
    Just do a slight varation on what Alice did in wounderland - not follow 'the yellow *****ed toad' but just follow the BRIGHT yellow wiring for the airbag which is CLEARLY seperated from other wiring in the car, as it should be!
    What is "stabilant 22" when it's at home?
    M-H-M use alloy wheel cleaner
    Sep 2010
    Naas
    guys detonators and airbag are disconnected (resistors 2.1 ohm for simulation) and still this same when ignition is on after 1 min srs light is going on.
    Launchx431 can read this airbag controller?
    Meat-Head's Avatar
    *THINKING* your module of full of water.
    look for thread 'accidental airbag triggering'
    Sep 2010
    Naas
    thanks guys I replace ecu and is working
