Page 112 of 126 FirstFirst ... 1262102107108109110111112113114115116117122 ... LastLast
Results 1,666 to 1,680 of 1877
Thread: GlobalTIS....
  1. #1666
    Oct 2019
    Duplicate, sorry
  2. #1667
    Oct 2019
    Hi wondered if you can help
    Tried generating my own key but getting a bad padding exception so guess it's only for an older version
    Just installed v40
    Request ID: R204223184
    Software Key: 6779-CB00-8215-F097-4B02-CFC5-B969-E466-AB06-AEE8-E0E3-22E4-ABE6-1C2A-6398-2E33
  3. #1668
    Jan 2020
    Hi i nee activation for global tis v40
    RequestID: R170865054
    Software Key:038F-51BA-0E64-8B0D-EE89-AE3B-67DE-B669-F25D-549F-74B2-70AC-4B5B-1227-18EC-1D42
    thank you
  4. #1669
    Jan 2020
    guys is something wrong with the number?
  5. #1670
    Bllinda's Avatar
    May 2010
    Baltic
    Quote Originally Posted by Haloweenhamster View Post
    Just installed v40
    https:/ /www.digital-kaos.co.uk/forums/forumdisplay.php/2-Introduce-Yourself
    Quote Originally Posted by Horstwerner View Post
    thank you
    This is the current topic for me in 2022.10.
    508 9HD 1.6 HDI_SID807_BR2 ( 19 Faults )
    today
    Subaru Forester 1999 sync. A pair of H44H and F93C46 is required.
    A topic that interests me
  6. #1671
    Oct 2019
    Quote Originally Posted by Bllinda View Post
    Thanks for the useful input, I posted there back in October when I joined when I was interested in the satellite side of the forum as I had just fitted a 9 input multiswitch & was looking at the best way of having 2 lnb's on 1 dish
    I originally got the tech2 in 2006 when I had a 98 Saab 900 & a 2004 Saab 9-3 and was active on saabscene, was even a moderator, I sold those & got a 2011 9-3 so had to update from tis2000 to globaltis, I also updated the vauxhall to globaltis upto 2009
    A friend asked me if I could program a 2010 vauxhall so I looked at updating and found V40 & cards 175 -184 which all look the same & upto 2014
    I can still do anything on my Saab, vauxhalls upto 2009 & diagnosis upto 2014 so the key isn't a big problem as I only help out friends & don't do it for a living it just would have been nice to have globaltis upto 2014
    If I could of generated my own key I would have but I have been unable to find the newer keygen
    If anyone could tell me what versions of globaltis cover what years it would be useful as I maybe able to use an older version that my keygen works on
    Anyone know what changes there are on the different cards?
  7. #1672
    Dec 2018
    GB
    T521967970
    D91D-266D-A51D-4F0B-234E-7C11-A47D-A6AD-2E3D-52D0-9DEA-84DB-A327-59C9-22F2-6B5F
    Globaltis v 40 for Horstwerner
  8. #1673
    Aug 2010
    Hello
    I need activation code for Global TIS V36
    RequestID: R199068074
    Software Key: D270-A047-43FD-8504-B945-5575-2F79-05CB-6C53-15B1-6AC9-7E48-AB1D-1155-4A7D-7278
    Thank you, bye.
  9. #1674
    Dec 2018
    GB
    T509630295
    5B0A-8119-4523-E7EE-9D44-9F7A-ECCD-E0CC-D187-CD68-F815-9230-C938-1821-33A2-76A0
    For Opel Corsa
  10. The Following User Says Thank You to ILIE71 For This Useful Post:
    Opel Corsa (27th March, 2020)
  11. #1675
    Aug 2010
    Hello,
    I had a problem with the GlobalTIS the server was not starting.
    I had to reinstall the software on a new virtual machine, can I have a new activation key?
    Global TIS V36
    RequestID: R750106411
    Software Key: FB96-934C-1DF7-E7F8-F7EE-E1B8-1D1C-037B-F4AD-8680-0F49-0252-006A-E0F6-F895-4F1E
    Sorry, thank you very much
  12. #1676
    Dec 2018
    GB
    Opel Corsa
    T298003387
    564C-5869-2B45-3620-3421-8B22-0BBF-16AD-3C91-420C-7224-301A-48CE-89F1-2248-3D33
    Salut , recomandarea mea este sa folosesti globaltis v32B . Depinde ce vrei sa faci cu el , dar v32 are ok functia sps programming si gds2.
    Daca vrei te ajut cu descarcarea si instalarea v32 . Eu folosesc windows 7 ultimate pe 32 biti si functioneaza ok . Banuiesc ca esti din Romania .
    Hi, my recommendation is to use globaltis v32B. It depends on what you want to do with it, but v32 has the function of sps programming and gds2.
    If you want help with downloading and installing v32. I use windows 7 ultimate on 32 bit native and it works ok. I guess you are from Romania.
  13. The Following User Says Thank You to ILIE71 For This Useful Post:
    Opel Corsa (29th March, 2020)
  14. #1677
    Aug 2010
    Thank you now it works.
    Yes I noticed that the version 36 doesn't have gds2 and sps.
    i think i will download version 32. i will try it.
    Thank you
  15. #1678
    Mar 2020
    Can someone do me a favor that find the file of GlobalTIS V25?Thanks.
  16. #1679
    Aug 2010
    Hello,
    I found and installed GlobalTIS v32 as you suggested ILIE71, can I have the activation code?
    Thanks. Greetings.
    RequestID: R173470266
    Software Key: C46D-3E96-25CC-28A7-626F-8B00-EB07-CA4A-804F-2B0F-6E39-9046-54C2-4DC9-ACA5-F6F8
  17. #1680
    Feb 2016
    Hello Patrian!
    Hello Friends!
    Please help me with a valid key
    GlobalTIS V40
    FED0-A687-5874-B813-FCF6-F1AD-EAAB-AD1E-D7F0-9351-DFF6-F8AA-7BB0-7F7C-5F40-030F
    Thanks in advance!
    Best regards!
    Dan
