Results 1 to 4 of 4
    Default Installation Order......XENTRY DAS WIS SDMEDIA EPC...???
    Hello.
    I have doubts about the order of installation of equipment for diagnosis MB.
    I had read once it is installed first and then the DAS WIS and Xentry ... Others say that you must first install the SDmedia .......
    My big problem is not how to operate the buttons on the left has Xentry.
    Thanks.
    PS: I use an automatic translator
    Quote Originally Posted by arielgam View Post
    Hello.
    Thanks.
    I think the most popular order is to install WIS NET Standalone and EPC NET first, then DAS of course before Xentry. SDMedia should be OK either way, just tick the option to update only.
    I'm afraid your problem would not be solved by the order of installation, you are probably expecting all buttons to work without an on-line subscription to MB in a few cases (VeDoc, EPC, TIPS).
    Thanks for your response.
    A greeting.
    Member avelest's Avatar
    next to the nearest the liquor store!!
    Hello.
    Thanks.
    There is no specific order to install, just remember that the das goes first. but like said in the post above, this will not correct the error for opening the wis straight from xentry.
    good luck!
