Results 1 to 15 of 17
Thread: x prog m eror
    Default x prog m eror
    heuy all frend i just bey chine clone x prog m V4.5 i tray te read whit it in dash kongo 99 with 68HC908AZ32A but whin read it it say device is silonce ..eror plz if sam one have solution for this
    May 2009
    hi
    xprog is not good for 908 mcus is better etl or upa
    regards
    so what i can do for it im just bay it all member hier see x prog is beter than etl and upa ..
    Bishop c4's Avatar
    chess board
    Hi, marassa device is silent becausse need more volt. you need a power source of 15volt. and 300ma or little higher
    hey bishop yes but win i tray to read with eny eprom all is ok jut in MCU it see device is silent.timeout error so must chang powr with hight volt ??
    Bishop c4's Avatar
    chess board
    yes marassa the reason is the mcu is more biger and need more volt power to work correctly try it and you see
    ok frend i tray and i report thnaks so mutch
    my frend i have ine 15v 500ma is it good ??
    Bishop c4's Avatar
    chess board
    the apropiate is 300ma find another for safety
    we dont want to make a mess right?
    Ecuador
    Smile Xprog Silence
    Quote Originally Posted by marassa View Post
    You must check the comport is not set correctly
    Best regards
    maybe you should lift some pins , like 2,3,26.
    all the pine ar good just for powr ihave one for 15v 500ma is it good or not ??
  13. #13
    hey frend im trey with power 300ma 15V not work ney change it see :device is silent.timeout error
  14. #14
    Bishop c4's Avatar
    chess board
    hello friend in that case you need to read all this tread
    http://www.digital-kaos.co.uk/forums...light=x-prog-m
    becausse the problem seems to be of another kind.
  15. #15
    yes but this just for updat
