Page 8 of 8 FirstFirst ... 345678
Results 106 to 115 of 115
  1. #106
    Jun 2011
    hi all. im trying to ftp a new version of a bouquet but dbe is asking to check my username and password. ive not had a problem before, they are both root and dreambox by the way. the only explanantion may be that im using port forwarding on my router to view the box away from home on the laptop via vlc player. therefore ports 21 and 80 are assigned to the box ip....is this interfering with my using port 21 from my laptop?
  2. #107
    digicon's Avatar
    Quote Originally Posted by zevrep View Post
    It should not interfere with it at all as DBedit connects via the usual ports whether open or not externally, Which brings me to another matter you do realise that opening the 2 most common ports externally opens you up for attack by any roving port bots looking for these being open, There was one not long ago that originated from Isreal just to give you the heads up
  3. #108
    Nov 2008
    hi ive followed instructions and edited channel list , saved it and sen it to box , it says successfully sent , but when i reboot the box , the channel list hasnt changed please help im using a dm500hd running pli image . thanks
  4. #109
    Jan 2013
    Have u choosed the right settings for the enigma ur box have?
    Sent From Tapatalk 4
    Galaxy S CyanogenMOD 10.1
  5. #110
    Nov 2008
    yes its set to enigma 2 for dm500hd ive edited the list and sent it ok but cant see it on box , have been reading that it could be because enigma 2 is running and i need to turn it off then send list then turn it on again , when i select reboot in dbe it doesnt reboot i have to do it using remote control . network settings are all ok between pc and dreambox , thanks
  6. #111
    Nov 2008
    its finally gone on , didnt do anything different , just rebooted using dbe and this time it reboot and put edited list on , thanks
  7. #112
    Nov 2008
    in future if i want to edit catseyes channel list , do i first have to put them on box and then receive them from box to dbe ? or can i edit the list before i send them to box ? if so how do i view the list on dbe ? thanks
  8. #113
    digicon's Avatar
    Quote Originally Posted by patch View Post
    Load into DBE first and then edit save and transfer to box
  9. #114
    Aug 2014
    it says
    Could not login to Dreambox. Check username and password.
    Disconnecting.
    Disconnected.
    what should i do????
    i used
    username root
    password dreambox
  10. #115
    DK Veteran porter1's Avatar
    May 2009
    liverpool
    tried many times over,struggling to see what im doing wrong nowadays,memory and health dont help,have recent catseyes file,any help appreciated,thanks
