Results 1 to 4 of 4
Thread: vectra c
    Default vectra c
    2002 reg. problem is speedo clock keeps going off, speedo, rev counter, guages, when it goes off does not clock up mileage, been told its cim module, does this sound correct or could it be something else. any help would be superb
    DK Veteran Larue's Avatar
    Somerset, UK
    Any faults logged in CIM, ABS, Dashbord?
    Ashraf6119's Avatar
    UK
    Most of the time its the CIM Module at fault which will be having all CAN Bus faults.
    But, worth checking ABS multi plug as there is a Modified harness for this fault.
    Also try to disconnect the CIM module plugs for few min some times it can cure just by resetting the CIM Module, but not 100% depends how lucky you are......
    Good Luck.
    Ash
    Thanks Ash
    Oh yes if my post was helpful than Please don't forget to press the Magic word Thanks
    Jun 2008
    common fault mate when it next goes off wack top of dash itll come back on, to sort proper whip the clocks out and make sound the connection ie replug and lock, its common thing mate they all do it just a bad connection.
