Page 1 of 2 12 LastLast
Results 1 to 15 of 16
    Nov 2009
    Default Another precoded transponder needed
    Hi Guys
    I'm sorting out all keys lost on a Volvo V40 2002 Tdi
    My AD900 will do the job but it's asking me for a 'precoded pcf7935 chip'
    How can I generate this precode from a pcf7935 chip ?
    Can it be done using the AD900 or do I need a Zedbull to do it.
    As a last resort can anyone do it for me ??
    Many thanks in advance
    Top Poster autocrypto's Avatar
    Jul 2010
    Default preCoded99 transponder
    If you need to clone your key, you need the preCoded99 transponder. Also used to clone the id:41, 42, 44, 45 and 33rolling only in AD900pro. No way to generate you need to buy preCoded99 to your local distributor.
    If you dont have any key for your car you need to generate a id:44 Mitsubishi(used in Volvo) in a virgin PCF7935 transponder. Is possible to generate in AD900pro if you have the module.
    You have equipment to program transponders in Volvo and the pin code??? If yes post the equipment and who you get the pin code witout make the dump of ECU.
    Best regards,
    AutoCrypto
    Nov 2009
    i have the module to generate mitsubishi id44
    i didn't realise that i could use the same one for volvo
    i'm not programming key on the car i'm using ad900pro to produce a key from dump of immobiliser ecu to start the car.
    ad900pro says to use a precoded pcf7935
    i didn't realise that i could make one using ad900pro
    many thanks for the info
    i'll let you know how i get on
    Nov 2009
    Quote Originally Posted by autocrypto View Post
    I have no keys for this Volvo
    tried to generate a virgin pcf7935as using ad900pro (china) 'generate id44 mitsubishi' but it keeps saying 'write error'
    i have the facility on ad900 to generate a key from dump for this car but it says to use a 'precoded pcf7935'
    is there any other way i can precode the chip
    any help would be appreciated
    Jul 2010
    Quote Originally Posted by tdor49 View Post
    I have only the genuine equipment, I dont work with china clones for the transponder cloning equipment.
    First: In your Volvo you have a Volvo immo 3 Bosch immobox. I am correct.
    I have checked in AD900pro/Megacopy and in Zedbull and the transponder used to produce a transponder by dump is a BLANC or VIRGIN PCF7935 and not a precoded transponder.
    You have already try to a PCF7935 virgin?
    If dont work you need to find a genuine AD900pro or Zedbull.
    Best regards,
    AutoCrypto
    Nov 2009
    yes this is the black immo3 immobox with 93c66 16bit chip
    when i load the file in the volvo immo3 section it tells me to use only 'precoded pcf7935' chip
    i have tried using a blank chip, but no good
    the software that my copy machine uses is 'tranpronics'
    when it says precoded pcf7935 does it mean use the precoded99 pcf7935
    many thanks in advance
    joubliss's Avatar
    Jan 2010
    Far away
    Default Precoded pcf7935
    try first to Generate Mitsibushi ID44 transponder in SPECIAL functions then try to program it.
    this is what happin always with chinise tool. alwats Fake...
    Job
    Nov 2009
    Quote Originally Posted by joubliss View Post
    Job
    already tried that but didn't work
    when i try to generate id44 mitsubishi transponder it tells me to use precoded pcf7935
    joubliss's Avatar
    Jan 2010
    Far away
    look mate, already talk with a friend, he told me that u have to use first ad90 to add a 8th Block cauz normaly its 7 blocks and ad900, after that u have to program it unto a blank pcf7935 to have a precoded one.
    not tested and im waiting to have more details.
    Job
    Nov 2009
    Job
    looking forward to having more details
    i have ad90 also
    many thanks
  11. #11
    Jul 2010
    Precoded99 is only to clone 41, 42, 44, 45 and 33rolling in genuine AD900pro and Megacopy only. Is not used to generate transponders by the ECU dump.
    You need to try in a genuine equipment. Your china clone is not ok.
    Best regards,
    AutoCrypto
  12. The Following User Says Thank You to autocrypto For This Useful Post:
    lmqcatarino (27th July, 2024)
  13. #12
    Nov 2009
    still struggling to find how to obtain or generate a precoded chip to use with ad900pro
    when it says use precoded does it mean that a genuine main dealer key has a code on it already ?????
    someone out there must have come up with the same problem before
    reading through the manual on the transpronics machine a lot of the 'generate keys from dump' need to use precoded chips
  14. #13
    May 2010
    Im have tools autel end need generic key for volvo v40 immo 3 with pcf7935 from dump, need transponder vergin or precoded?
  15. #14
    Jan 2018
    Ad900 asks for a 99precode transponder have tried to generate myself but hit or miss
  16. #15
    fred77's Avatar
    Jun 2019
    Crazy idea ....call an auto lockie
    or someone who actually spends money on kit
    Solidarity with Ukraine
