Results 1 to 13 of 13
    DK Veteran elecautocr's Avatar
    Feb 2010
    Default Bus Mercedez Benz 904 ECU wiring diagram
    Hello members:
    I need the wiring diagram for Bus Mercedez Benz 904 ECU. Engine is MD0141860. I am attaching picture of ECU. Thanks very much for you help
    Member zozi's Avatar
    Feb 2010
    Hungary
  3. The Following 9 Users Say Thank You to zozi For This Useful Post:
    eddav74 (26th February, 2015), elbarto (15th November, 2024), jdm (18th November, 2021), jo?o antonio (19th August, 2017), juan79 (4th February, 2015), luomgofe76 (6th March, 2015), mecanico (4th May, 2014), peter21 (2nd November, 2014), Vicus2000 (22nd September, 2013)
    Feb 2010
    Thanks very much
    May 2010
    just to let you know there is another computer inside the vehicle for things like cruise, engine brake,throttle etc.., what kind of issues are you having? just curious.
  6. #5
    Feb 2010
    Engine don't start, ecu is full with oil and water !!!!, I just want to test basic things in bench
  7. #6
    May 2010
    Quote Originally Posted by elecautocr View Post
    the ecu was filled with oil and water, yikes!
  8. #7
    Feb 2010
    Hungary
    Check the following if you do not rotate engine
    ECM plug connection X1 [16pin]
    pin5-terminal 30
    pin6-terminal 30
    pin8-terminal 50 [input]
    pin9-terminal 31 [ground]
    pin11-terminal 31 [ground]
    pin12-terminal 50 [starter actuation]
    pin15-terminal15
  9. #8
    Nov 2010
    It would like to know if somebody has scania information on repairs of ECU of trucks Mercedes and volvo to share debtor
  10. #9
    Jan 2011
    Thanks very much
  11. #10
    Top Poster peter21's Avatar
    Nov 2009
    San Miguel, SV
    Default boot pins
    hi guys, maybe someone can help me with the boot pins for the PLD and VCU, the engine is a MBE 906...... thanks in advanced...
  12. #11
    Feb 2010
    Hungary
    This is a must for you. Originally Galetta TO 1250
    I hope I helped
  13. The Following 3 Users Say Thank You to zozi For This Useful Post:
    jo?o antonio (19th August, 2017), juan79 (4th February, 2015), peter21 (2nd November, 2014)
  14. #12
    Nov 2009
    San Miguel, SV
    Default thanks
    thank you sooo much buddy for the help, maybe can help me too for boot pin of the VCU, i need update the software from 1.0 to 14.00..... the VCU is mounted on freightliner truck, model bussines class....
  15. #13
    Aug 2009
    someone has MBE 906 engine diagrams ..... thanks in advance
