why do you want to reset adaptive values?
does anyone know how to reset adaptive values? disconnect battery? ignition key tricks turns off and on? etc
op-com doesnt support my ecu ("reset iac block learn map" option not available) even if i select 1993 astra-f c14se
unidiagkwp2000 is for kw2000 protocol and kwp71diag is kw71 protocol
my ecu is kw81 protocol
suggestions?
Yes, but kwp71 also has option to work with kwp81 protocol
Galletto 2012 v54 full with JTAG and Mini available
Big Stars never dies:
Colin McRae (1968 ***8211; 2007)
Richard Burns (1971 ***8211; 2005)
Georg Plasa (1960 - 2011
exhaust was blocked, i changed it, i want to reset it all
thanks m8, but which is "reset adaptive values" command to send to ecu?
by the way, kwp71diag version i got doesnt have options to select protocol, can you say where can i download your version?
i found kwp71diag with kw81 option here
http://rapidshare.com/files/146825001/kwp71diag_N.rar
but dont know "reset adaptive values" command
This particular ecu doesn't have the option to reset adaptive values. Try disconnecting the battery for a short time.
Hi,mates.I agree, also, to reset the ECU this year's production can make in this way,first of all I think on the clear error.This ECU is poor with a memory and data in relation to today's vehicles and engine ecu,therefore can not manipulate something significant with them in this modern way of what we now expect.Best regards.
