pt cruiser 2 ltr non turbo will not idle, it will only idle with an air leak.revs up fine though any ideas any 1
what sort of idle speed contol valve does it have ? Try cleaning the throttle body with carb cleaner
ive put a new idle speed control valve on it and cleaner the throttle body with carb cleaner
Any codes? Signal voltage and reference voltage present? What are the live data readings for IAC?
Yesterday we stood in front of the abyss. Today we'll move ahead.
If you need any repair manual, pm me- maybe I can help you.
no codes everything looks ok on live data
How about voltage supply to control valve? Did you calibrate the new valve?
no ive got a launch and a modis and neither will do it
I had similar situation.
Spark plugs had big gap, i replace them and spark plug cables too.
Some interference i believe, cosed by bigger voltage.
il give tht a bash tomrow its just has head gasket somewhere else and brought here because it wont idle...
1) Second about the spark plugs and HT leads - seems to ring a bell
2) Head gasket - Is there any Helmons Mayonase in the cranck cas breather pipes.
3) OFF TOPIC:-
*THINK* it is some vauxhall in the air filter box is a piece of 'brilo pad' remove this and use to polish somebody's car you don't like.
