Can anyone suggest a cable receiver that can support CCcam that has an RF modulator (for connection to a TV)...?
My m8 wants to share my VM card but he needs the box to have an RF out as well as RGB (scart)
Cheers
Cheers
dreambox 500c
Wavefield Ds 55cm at 13E 19E and 28E receiving everything out there on 2 dm800hd
previous life dm800hd and 500c on cablescrew you nag3
I bet myself someone would say that...
It's a tuner loop through for daisy-chaining other cable receivers...
It doesn't modulate the currently selected channel over UHF..
Anyone else![]()
get a dm500c and a Labgear rf modulator
I wonder if the openmedia box has an RF modulator...
Tell your mate he'll be lucky to get 20 active users on your VM card.
maybe a little expensive but consider a DM7025, you wont find a better box for what you want
DreamBox DM 7025 Specifications:
- 300 MHz Processor
- Linux open source (most parts under the terms of GPL)
- Supports Linux Standard API
- 1 x DVB Common-Interface Slot
- 2 x Smartcard-Reader
- Integrated Compact Flash Interface Slot
- MPEG2 Hardware decoding (fully DVB compliant)
- TWIN Tuner, mixable, Plug&Play
- Tunervarianten DVB-S, DVB-C und DVB-T, pluggable
- 10/100 MBit compatible Ethernet Interface
- USB Port
- 12V switch cinch
- V.24/RS232 Interface
- Big-size LC-Display
- 32 MByte Flash
- 128 MByte DDR-RAM
- integrated IDE UDMA66 Interface
- Support for internal HDD in any capacity
- unlimited channel lists for TV/Radio
- channel-change time < 1 second
- full automatic service scan
- supports directly bouquet-lists
- supports EPG (electronic program guide)'
- supports multiple LNB-Switching control (supports DiSEqC)
- fully adaptable OSD in many languages and skin-support
- S/PDIF Interface for digital bit stream out (AC-3)
- 2 x Scart-interfaces
- RF modulator
- Audio/Video cinch out
- MINI-DIN connector for extern IR (send)
I don't follow you m8, who mentioned anything about 20 clients...?
I have a VM N3 card in my DM500S (I don't have a cable feed) running SBox and I'm sharing it with a few m8s/family members...
One of them though needs an RF out capable STB as his other TV's are on a UHF circuit..
Thanks for the info re the OM Box though. They aren't that easy to find online either so I'll have to research the ouputs on it...
Thanks for that. I did see that unit but I couldn't find one anywhere. I wondered if they had been superseded or not now though..
Cheers
Or if he got an old VCR lying around he can scart to it from 500c and then rf out to tv
