Results 1 to 15 of 17
    Default [Help]Problem with W211 2003 no mileage display
    I've encountered a Mercedes W211 E240 2003. I've tried to read the dump of the EIS to make a new key using Xprog-M but I've selected the wrong type. It is a HC912 3K91D mcu but I've selected 9S12 type, when I use back the correct settings the flash & eeprom is already corrupted (all FF).
    So I've use another backup full dump from another car done previously to recover this car. I've used another W211 E240 ECU eeprom, EIS flash + eeprom to remake the key. I've edited the VIN number to match the car I'm doing.
    Now the car is able to start and I've erased all other fault code and do all the neccessary coding to SRS. Everything is fine now but the problem is the mileage section no numbers at all!
    May I know what should I do to make the mileage display as the EIS and ECU dump are from another car and VIN was edited to match this car?
    u can sent me the file for you instrument cluster, i can edit for u
    workshop
    Quote Originally Posted by jckhing View Post
    you can this see ------ ?
    enable piepwarning with star diagnosis,after can you milage see
    Quote Originally Posted by kentzee View Post
    Do you mean that the instument cluster and EIS mileage must be same only the mileage will be displayed?
    Quote Originally Posted by mercis View Post
    Yes I saw -------- in the dash there? So may I know how to enable piepwarning? where is the piepwarning? Is it in IC section?
    jevgensolo's Avatar
    May 2009
    Ireland
    You must change mileage on DASHBOARD to any mileage in range 0-200 km.I make usually 0. After that You can make Dashboard-EIS adaptation with STAR DIAGNOSTIC. And mileage from EIS will come to dashboard.
    workshop
    steuergeraetanpassung after reset KI
    Quote Originally Posted by jevgensolo View Post
    May I know what tools to be use to change mileage to 0? If I use normal eeprom programmer to program the chip soldered out of Instrument Cluster and use hex to edit it is it ok? I've Tachosoft Mileage Calculator cracked downloaded from this forum. I've checked it is only able to let me edit until 100km but not sure how to do it to zero.
    Top Poster Artjom's Avatar
    Oct 2010
    Kiew / Hamburg
    Hallo guys, have similar problem .. a coustomers changes the instrument (tacho) because the original was stollen...
    not just show ---- instead of the km...
    What the way to got... can i solve this problem using STAR ? or do i have to desolder some chip ... in order to make the tacho virgine (km 0-200) and programm it new?
    Can someone make the Dump virgine when i read out.. ? and what chip to read?
    workshop
    24c17 eeprom
    write chip under 200 km and learning to eis
    Nov 2010
    print or write down original coding and mileage
    put all line mileage 24C17 to FF
    go to star , dashboar
    make adaptation
    folow instruction
    at the end you will see ame mileage in EIS
    by the way if you bring other file from car , you must modifie VIN number to original VIN , otherwise you will got
    trouble fault in SRS (air bag) , in ESP and SBC
    take care
    Oct 2010
    Kiew / Hamburg
    so i can just use tacho pro to make km to 0 and the code it ? right .. no need to desolder the chip and change the vin by hand?
  13. #13
    workshop
    Quote Originally Posted by Artjom View Post
    tachopro???
    you mean tachouniversal?
  14. #14
    Oct 2010
    Kiew / Hamburg
    yes that what i mean ..
    Today i had a problem and wanna chare it with you...
    One guy tryed to make tacho on the E-Klasse W211 2003 .. he killed the EZS by reading with rosfar clone..
    then he got dums of other ezs.. and adapted ecu and esl .. and keys .. to that ezs dump..
    he also made the ezs virgine.. so we could code it.. no vin and 0 km..
    the ezs was coded... car started but in tacho we just ----
    we tried everything.. but still ----- then we though maybe some idiot flached tacho before.. and we made tacho to 0.. and then everything was ok...
  15. The Following User Says Thank You to Artjom For This Useful Post:
    clauberty (26th January, 2016)
  16. #15
    Nov 2010
    hi
    write the brightness zone all to FF
    make adaptation with DAS
    thats all
    display will dispaly sure
  17. The Following 2 Users Say Thank You to DJAMY For This Useful Post:
    godax (21st February, 2020), nstnkt (9th March, 2023)
