Search for a free version of race2000 pro
edz0n (13th October, 2018)
Me too. but i think dont have![]()
El Cordobe!
RASCH MotorSport
Your temporary key has expired!
Privremena registracija programa je istekla!
need key and name !
Please reup new version with crack.
BR
https://rs43tl2.rapidshare.com/#!dow...|99614|R~0|0|0
https://rs157tl6.rapidshare.com/#!do...|60294|R~0|0|0
password: princorecycle
but Work only 7 days,
you must use this prog:
http://www.nirsoft.net/utils/runasdate.zip
RunAsDate is a small utility that allows you to run a program in the date and time that you specify. This utility doesn't change the current system date and time of your computer, but it only injects the date/time that you specify into the desired application.
You can run multiple applications simultaneously, each application works with different date and time, while the real date/time of your system continues to run normally
good luck
paolo poppi (12th February, 2020)
When try to run the loader ... Set it back to 5 years ago ... and still doesn`t work.
CMD Electronics, Co.
1300 Kaplara 14/4
+381 21 466 129
+381 65 808 8203
office@cmdelectronics.com
Reinstall Race![]()
this is the first install...
works well for me, if someone has a better version, or race evo can post it
hello,
i have the race2000 and it work good when i open it at the year 2011, but it must do the update to work good.
This soft isnt a bad soft, but its old!!! i think its end at 2007.
regards.
WORK WITH KWP 2000+, GALLETO 1260, BDM 100, FLASTEC CLONE WITH MAGPRO2, VAGCOM, FIAT ECUSCAN,UPA USB, MAXIDIAG, TOP 2049, PROG EXPRESS, AND MORE....
when i run setup exe the screen become bleu and not think happen,no instalaion!!!
try to start first loader and then setup.exe
i did it
i had run loader and i had enter the serial number
same probleme
