Page 2 of 2 FirstFirst 12
Results 16 to 25 of 25
  1. #16
    Sep 2009
    well , i gave up.
    no chance of comunicate with st...
    maybe next will work.
  2. #17
    Jan 2010
    I`m also joining the club from people wo could not read the st6245 from a twingo.
    Try it 10 times and check al connection, but no result.....
    Frustrated now
  3. #18
    honingkoning's Avatar
    Jun 2010
    Dessert
    Quote Originally Posted by gijsvm View Post
    Frustrated now
    Did you lift pins like mentioned earlier in post
    Maybe hardware problems, try to test your hardware.
    I dont know where you are located in holland,otherwise you can try mine device.
    Regards Honingkoningg
  4. #19
    Jan 2010
    I lift 9, 11, 13 etc.
    Still nothing, test upa with eeprom and reading was good.
    Ok, contact you....
  5. #20
    calin_bm's Avatar
    Jan 2010
    near civilization
    so, upa final can't read ST6245 from Borg dashes?
    anyone have managed to connect and write ok this device?
  6. #21
    Jun 2010
    Dessert
    Quote Originally Posted by calin_bm View Post
    so, upa final can't read ST6245 from Bord dashes?
    No problem mate i use connections from upa PDF and lift pins that are mentioned in TU manual.
    Peace of cake.
  7. #22
    ubistvo's Avatar
    Sep 2009
    SERBIA Krusevac
    Sometimes its a problem in SOFTWARE
    1. Try to reinstal upa software
    2. Try on some another windows
    3. Try to read with win98
    I have the same problem and this is work for me
  8. #23
    verica's Avatar
    Mar 2010
    MACEDONIA
    Smile
    i have problem to read this mcu also but i dont remember witch upa usb softvare have problem to read this mcu i think 10.xx but if you try with older version than 10.xx you will read it without problems tested 100%
  9. #24
    Jul 2010
    Quote Originally Posted by honingkoning View Post
    Hello mates,
    Can someone tell me how to connect a st6245 with upa
    i would like to know which plate to use.
    and if it's possible also for other mcu (something like a manual).
    Best regards Honingkoning.
    HELLO
    UPA can do this dash expeted the first generation of twingo
    modele borg maybe the oscilator is not supported by UPA
    i use the diga clone for change the mileage
    regard
  10. #25
    Mar 2017
    Hungary
    I am trying to read a ST6245 MCU with UPA 1.3.
    Pin 11 (TEST PIN) lifted and and did the connection as in uuprog.pdf and still "Device not respond"
    Tried both with 5V and 3.3V.
    Can anybody help me?
