Results 1 to 14 of 14
    Feb 2010
    Default DM800 - TV does not auto detect signal when switched on
    Hello,
    Got a small problem with me DM800.
    I switch my TV on and once thats powered on I switch on the DM. But the TV just sits there doing nothing.
    With my dm500, cable box, blueray player, xbox etc when I do this it automatically switches to the device just turned on.
    It doesnt do this with the DM. Both on scart and HDMI-DVI cable. It just doesnt auto detect, so I have to go into source in the TV menu and select the source, say hdmi.
    I have tried a new scart cable. Tried a new DVI cable. Have turned the TV off from the plug and back on again, tried different ports. Still the same.
    Any ideas? Or have I just got a duff box?
    DK Veteran deffc0n's Avatar
    Aug 2009
    UK/POLAND
    Very strange.
    My DM always switch TV.
    What you have image inside DM ?
    I use Gemini no problem anything.
    Bulld0g's Avatar
    Apr 2008
    Liverpool
    Is it set to DVI under A\V settings ?
    V.I.P. Member dctyper's Avatar
    Jun 2008
    yes make sure its set to dvi
    dc
    Wavefield Ds 55cm at 13E 19E and 28E receiving everything out there on 2 dm800hd
    previous life dm800hd and 500c on cable screw you nag3
    Feb 2010
    Yup its set to DVI. It doesnt show a picture if set to anything else. Seems somethings stopping the auto switch signal being sent, or the box aint sending it at all..I can switch to it using the source button on the tv no probs.
    Dm500 works fine. auto detects straight away.
    Have tried a few images. Currently running DreamElite BH 133 with updated drivers.
    Tried OpenPLI and Gemini image too.
    Bulld0g's Avatar
    Apr 2008
    Liverpool
    Have you got another DVI lead to try, it does sound like a dodgy box though m8
    Jun 2008
    are you using an original cable?
    Feb 2010
    Have tried a different scart and a different HDMI...Supposed high quality one! Still the same.
    Just tried on another TV which isnt HD with a scart. It picks up straight away. Obviously cant test with a HDMI cable, but scart doesnt work on the HD TV either.
    But it cant be the TV cos all the other devices work fine, it just doesnt seem to like the dm800.
    Gutted if its the box. Bit annoying selecting it from source each time.
    Cheers guys.
    V.I.P. Member SGTFlipFlop's Avatar
    Sep 2009
    Scotland
    My TV has an option to start up in TV mode or AV mode, See if yours has that option in Menu > Setup
    Feb 2010
    Thanks mate,
    Checked tv but it hasnt got those settings. Its a samsung series 9.
  11. #11
    Mar 2009
    hi try turning the box on first let it boot all the way then turn the tv on should auto find the box works on samsung 3d tv should work for you cheers plonker
  12. #12
    Sep 2009
    I have an exactly same problem as you deldoy. Previously I was using DM500, and had no issues at all, last week I bought a new TV and started using DM800, but when I turn the receiver on nothing happens! The box is connected with HDMI-DVI cable only to AV Receiver. Any help would be much appreciated.
  13. #13
    Sep 2009
    Anyone please?
  14. #14
    Feb 2010
    Quote Originally Posted by plonker View Post
    Tried that mate. Still dont work. Gotta select manually.
