hello can anyone point me in the right direction here i need to reprogram the U3 and U4 chips 29F016 with the dumps from here but im having trouble reading / writing these with my willem and adaptor, could someone post the jumper settings for the adaptor / willem or point me in the right direction with settings for programming these chips
many thanks
Hello friends! I wonder if someone already managed to upgrade to some version SBB Chinese well today, for example the V37. If yes how did they do? What is the largest version that could run on the clone without problems?
sorry for my question but what is better the sbb or the t300 or mvp and what version?for european cars most?and need tokens?or unlimited thanks
Now its ok ...
i put in power cable. Is restarting and its ok .
my rs232 is not conected ... how can i know what pins ia coresponding on sbb board ?
thank you
Turbochip for that your SBB needs a chip...LT1133ACSW. Is for RS232Port (a kind of max232 but not the same).
Can you put a picture here ?
I want to update (downgrade) my SBB v33.02 to 33.01 which is better, right?
Is it possible to update using Wintransfer only, whithout desoldering U3 and U4? To go from 33.02 to 33.01 do I need to change the 24c16?
Thank you!
im sorry to bull this old topic up but i really need some help..
three months ago i used my sbb clone on a hyundai I30 2010 and i couldnt get connection, i asked afriend to came wth his sbb and did the job (a new key), i noteice that his db fram newer than main so i google for an update and i found the best fourm in world, i mannaged to update my sbb from 30 something to 33.01 buy the help and files i found here. and i thought that the problem fiexed.
today i had another hyundai toucon 2010, and same problem the machine keep telling me to close and open car switch for three or four times and then cannot connect to ecu.
i had read in this fourm that may be there is some ics or really that is broken and need to be replaced, but i cant find that topic again.
so if any one can help me with that. and here is a pic of my Pcb
P.S. i had done a couple of golfs under 2003 and a fabia 2005 before the update, and i cheked the odb2 cable on onther working sbb and its ok
and i update my sbb via rs232 and here is a pic of it
please . How do I update my sbb china v33.02 to 33.01 , i need read pincode gm brasil
anyone has sbb v48.88 dump?
Anyone have a batch from China V48.88?
