We know as said above regards E1 and E2.
I refuse to answer that question on the grounds that I don't know the answer. - Douglas Adams
when did they change it? i used to dl it all the time on my 500s!
Wavefield Ds 55cm at 13E 19E and 28E receiving everything out there on 2 dm800hd
previous life dm800hd and 500c on cable screw you nag3
The guide is an amalgamation of a lot of peoples work as the original author has said elsewhere and gave thanks to those involved.
Thanks for the pm and I will take some cream with my humble pie and thanks again for your tut. I will merge the two threads together as it will make them easier to follow.
Last edited by satsmo; 2nd November, 2010 at 11:35 AM. Reason: I can be an idiot at times
Have a beer instead mate, i understand why you had to check it out and appreciate the fact that you did.
What image and skin is that you are using on your DM500?
Thanks, Just tried it and its quite bright LOL
I need help please.
I got PLI image d500s sky UK EPG some channels missing and is not update EPG every 3 days I have to download. Can anyone explain to anything wrong please or is normal like that to download every 3 days. Thanks
ok thanks........
The cronjob to autoupdate i found to be a bit hit or miss,also to keep the size of the file down it is better to reboot your box and do a manual retrieve when required.
thanks for the tip ,had a buddy lend me a hand ,
dont know what
use cron does but mine is ticked , my /var used is 56%
im testting it now ,
Guys, ive managed to mount my dm500s ok, BUT I cant download the epg plugin as it says 'server offline' or something like that! Im using jade pli image, so any ideas?
