Page 1 of 4 1234 LastLast
Results 1 to 15 of 48
    Sep 2010
    Default China MVCI trouble
    Hello.
    Got an MVCI from China, working good. BUT! After last online update to 1.4.7 firmware (flash was successfull) it does not work anymore. Techstream does not connect to VIM, and it is no firmware version in the info about the device on the XHorse firmware update tool. It can be reflashed to version 1.4.7 again, but it does not help - firmware version still missing after flashing. Dont know what to do.
    Thanks to any answers.
    DK Veteran ishell's Avatar
    Russia
    Quote Originally Posted by Sted View Post
    Hello.
    Go to setup option of tis (vim select) and choose your interface type .You have vim selected now ! Not mvci .
    And do not forget closed firmware utility before using tis .
    FU#K GOOGLE. ASK ME
    Sep 2010
    Quote Originally Posted by ishell View Post
    Does not help. X-Horse MVCI choosed from the list. Driver were closed. Still no connection to device. Maybe enyone have *.mfu file for offline update?
    I hear about this problem with 1.4.7. Try back to older firmware.
    I have old firmware on my work, but i will be there only 8 november. If you cant find old firmware before i go work then PM me, i send you file.
    Sep 2010
    Ok, i'll wait. Many thanks.
    I used 1.4.7 MVCI version with Techstream - it works good.
    i have mvci firmware 1.4.7 and didn`t go..but i have try with driver 1.4.5 and 1.4.6.. anyone have the 1.4.7 driver?
    Looking for firmware for MVCI (later than 1.4.5)
    Quote Originally Posted by Anisimus View Post
    After install software to 1.4.8, i can update firmware to 1.4.7
    _http://rapidshare.com/files/431693470/MVCI_Driver_1.4.8.rar
    Sep 2010
    Yes, me too. Problem were solved by manual firmware update to 1.4.7 using *.mfu file, i got from my seller. Driver 1.4.8 were installed after, and work with Honda worse than 1.4.6.
    Yes, me too. Problem were solved by manual firmware update to 1.4.7 using *.mfu file, i got from my seller. Driver 1.4.8 were installed after, and work with Honda worse than 1.4.7.
    Can you upload mfu-file to rapidshare etc
    Sep 2010
    Yes, sure. But use it on your own risk - it's for my serial number!
    _http://rapidshare.com/files/431719108/MVCI001000389_1.4.7.mfu
    Thanks to www.autotoolz.ru
  13. #13
    Do you have orther firmware . after up firmware to 1.4.7 . My tool show "communication error". thank you.
  14. #14
    Dose any body have 1.4.7 or 1.4.8 (if exist) mfu file? Links from these thread not working any more.. Thanks in advance
  15. #15
    Need 1.4.1 *.mfu for repairing my china xhorse mvci. Can someone upload or send me this file?
