Results 1 to 8 of 8
    Feb 2010
    Default golf 5 visteon 95160 pin
    hi i need the pin of this dash visteon i need for change for vdo dash .
    regars
    Hello!
    Search in engine ecu for pin code!
    ?s it possible to change visteon - Vdo without problems?
    Nov 2009
    South Africa
    you need very expensive tools to extract pin from ecu via obd. depending what ecu you have. med9 alittle difficult.
    You can try with Vagdashcan, support PIN reading for Visteon.
    Nov 2009
    South Africa
    hi autofan1965. i have a very stupid question. how do one determine if the dash is visteon. thanks.
    Feb 2010
    Default pin
    i see in the forum that people find code by 95160 visteon.
    http://www.digital-kaos.co.uk/forums...n-code-170345/
    Visteon is probably only by Golf 5 Plus and have rough button, VDO have smooth buttons.
    Feb 2010
    Default dash
    my dash is visteon and no is of golf plus it is a normal golf
