Lexia PP2000 repair - Page 15
Page 15 of 24 FirstFirst ... 51011121314151617181920 ... LastLast
Results 211 to 225 of 355
  1. #211
    Sep 2011
    Hungary
    Does someone know what is the problem with my interface. Lexia doesn't work with Xsara Picasso 2.0 HDI. Diagbox works with Peugeot 307 (my.2007) and Citroen C4 Picasso well. Lexia also works with Citroen C4 Picasso, but with my Xsara picasso no communication.
  2. #212
    dunkler's Avatar
    May 2009
    Hatzfeld
    titoun
    So far I've checked PIC and its missing VCC so it looks like a HW problem
  3. The Following 2 Users Say Thank You to dunkler For This Useful Post:
    Col19 (24th January, 2020), krevetbre (5th April, 2019)
  4. #213
    lion0304's Avatar
    Oct 2014
    Default Device not detected
    I have my Lexia with 2 USB cable. One long and short.
    The long never work, when plug, led bright but windows show device not detected.
    I use the short USB cable work until now and last days need moved when plugged to make working device.
    So i take out the DB15 connector, and remake all solder point with the same cable ( need cut 15cm shorter)
    Now it work very well the older long cable. Here is diagram pinout USB to DB15.
  5. The Following 8 Users Say Thank You to lion0304 For This Useful Post:
    Col19 (24th January, 2020), krevetbre (5th April, 2019), mek007 (10th May, 2020), mexanico1971 (25th March, 2020), okm (6th February, 2018), slawcio26 (28th June, 2016), titoun (29th March, 2016), violator11 (7th June, 2016)
  6. #214
    titoun's Avatar
    Dec 2010
    Vdd (Vcc) or Vpp on PIC 16F ?
    If you are sure that it's Vcc, first check 5Vdc on relay pcb : output of LM2674 M 5.0...
  7. #215
    N.Ireland
    Having trouble connecting to Peugeot 307 2006, Couldn't get Vin or connect to BSI also didn't hear relay click
    Very few ecus found.
    Fault was one of the relays open circuit, Relays should read about 140 ohms
    I checked them all and only found one bad, Not sure if relay can or van
    Andy
  8. #216
    titoun's Avatar
    Dec 2010
    Check if there are connections between this relay (NAIS) and MCP2551 component right next ?
  9. The Following User Says Thank You to titoun For This Useful Post:
  10. #217
    N.Ireland
    I just measured the coil on each relay
    The coil is the 2 pins indicated , Check these pins on all relays
    The NAIS relay if the one I replaced which is why it is a different size (only type I had)
    Measure the same 2 pins on all 12 relays and check they are all about 140ohms
    The one I replaced was open circuit
    Andy
  11. The Following 2 Users Say Thank You to andye26 For This Useful Post:
    Col19 (24th January, 2020), titoun (4th April, 2016)
  12. #218
    Apr 2016
    My lexia3 : if connected to my PC, the green LED don't work. Before it worked well.
    Please give a solution..
  13. #219
    lion0304's Avatar
    Oct 2014
    If Lexia work partial, rework all solder points. Use Hot air gun + solder flux.
  14. The Following 2 Users Say Thank You to lion0304 For This Useful Post:
    Col19 (24th January, 2020), titoun (13th April, 2016)
  15. #220
    Apr 2016
    At the beginning worked for 3 seconds and goes out.
    Then open and close and began to work well.
    Now lexia completely stop.
    I do not hear and distinctive sound when you turn on USB - nothing is connected to the PC.
    Forgive me for my english.
  16. #221
    titoun's Avatar
    Dec 2010
    Try to change RAM SAMSUNG K6X and if always don't work, reflash microprocessor MB90F546GS (with nlc firmware or hardware method).
  17. The Following 2 Users Say Thank You to titoun For This Useful Post:
    Col19 (24th January, 2020), pu6olin (14th April, 2016)
  18. #222
    Oct 2015
    Hi, I have problems with my new interface. I can't connect to Engine and ESP in any car (406 coupe 2.2HDI and 307 2.0HDI). Other systems seems to be ok, so I don't know if my interface have problems with CAN maybe?
    Wich components should I check??
    Thanks!
  19. #223
    titoun's Avatar
    Dec 2010
    Try this :
    http://www.digital-kaos.co.uk/forums...tion-problem-!
    And if your interface always don't work, check welds of relays, MCP2551, TDK common choke on Relays PCB.
    After check welds on HC04, optocouplers 0639 and HC 08 on Microprocessor PCB.
    For my part, i will replace all HCPL 0639 optocouplers be HCPL 063N.
  20. The Following 2 Users Say Thank You to titoun For This Useful Post:
    Col19 (24th January, 2020), Perryking (10th May, 2016)
  21. #224
    Oct 2015
    Thanks titoun.
    My interface doesn't have the CAN resistor, so I'll try your solution.
  22. #225
    Apr 2016
    Hello again.
    I changed my RAM chip but the problem remains.
    Computer does not respond inclusion of pro usb and LED does not light up.
    It can be damaged usb chip?
