good . lexia repair keygen post
please
please
Tested on VAN CAN working OK. Cheers
To admin - remove this message, please
12V/5V converter is located at right side of the multiplexer PCB (see photo). Here you have the documentation to the controller of the inverter.
titoun (18th February, 2016)
See this page :
In-System serial Programmer 16LX and FR FLASH MCU.
I have problem that CAN cars cannot be connected, I can read VIN from car, but then diag application refuse to start. Any idea?
Hi !
I have a "minor" probleme using the Lexia3. I can't comunicate with the newer (after 1999) clima ecu of the Xsara/Xantia car. If I watch the signal on an oscope the ECU is respondig to the diag interface but the soft (Lexia3 45) report is "no response from ecu". I tried with other clima ECUs (same number/revision) but no change.
What shoud I try first ? Instal older version of Lexia, reprogram the interface (pic,...)
Hi all
My interface after connecting to pc the green light turns on then off after 2-3 sec. If I start lexia or pp2000 the pc restart's with bsod massage bad_pool_header. What can be the problem.
Click here:
http://www.digital-kaos.co.uk/forums...52/#post849779
I bought a Lexia and it was not detected by software.
I opened the box and saw that the worker which connected the cable connector to the PCB pushed it badly and made a short between the two marked pins (the sixth pins from the top)
I fixed the connector and the pins and now the software detects the cable but when connecting the car I hear the relay bat no communication with the car.
I suspect that the short made a problem but I can not find which components connected to these two pins
Anybody can help?
Hi I have a problem with the inverter in my Lexia at this point it should be 5v and I have a short to ground
