Page 2 of 2 FirstFirst 12
Results 16 to 18 of 18
  1. #16
    Top Poster + Iroll's Avatar
    Sounds like SQL conflict.
    What other software do you have installed?
    IE7 IE8
    Clear the cookies and temp files in IE.
    Internet Options\Advanced Tab (Restore Advanced Settings) (Reset IE Settings)
    Add or Remove Programs:
    Microsoft .NET Framework 3.5 is OK. ?If you have 4.0 remove it!?
    Remove VIDA
    Restart:
    Remove:
    SQL Server 2005
    SQL Native Client
    SQL Server Setup Support Files (English)
    SQL Server VSS Writer
    MSXML 6.0 Parser
    Restart:
    Above SQL programs are installed by VIDA
    Remove all other SQL Programs that are installed. Other SQL software will conflict.
    Restart:
    Delete:
    C:Temp (if present)
    C:VIDA
    C;VIDASave
    C:Volvo (if present)
    C:\Program Files\Volvo & Volvo Cars (Delete ?Volvo & Volvo Cars? Folder)
    C:\Program Files\Microsoft SQL Server (Delete ?Microsoft SQL Server? Folder)
    C:\Program Files\MSXML 6.0 (Delete "MSXML 6.0" Folder)
    Run Registry Editor:
    Backup Registry!
    HKEY_CURRENT_USER\Software\Volvo
    (Delete ?Volvo? Folder)
    HKEY_LOCAL_MACHINE\Software\Ford Motor Company
    (Delete ?Ford Motor Company? Folder)
    HKEY_LOCAL_MACHINE\Software\Volvo Cars
    (Delete ?Volvo Cars? Folder)
    Restart:
    Install VIDA:
    Select ?VIDA Customized? on setup page.
    Check only:
    Microsoft Windows Installer 3.1
    Microsoft SQL Server Express
    Un-check everything else click next
    SQL will take some time to install, Ignore errors!
    If this goes smooth, restart computer!
    Install VIDA select ?VIDA All-in-one? on setup page.
    Iroll
    Please! Don?t forget the ?Thanks Button?
  2. #17
    VMware!
  3. #18
    DK Veteran labusas's Avatar
    Nov 2010
    I setup VMware, spent 3 hours just to find out at the install start that VIDA requires 1g RAM. I only have 1 g RAM in this laptop and VM can't have that much. So I ordered an upgrade to 2g. Will continue when get it.
    It looks like it will be the ticket!
