Page 3 of 4 FirstFirst 1234 LastLast
Results 31 to 45 of 53
  1. #31
    Apr 2013
    Great work maxtdi just got an volvobrik with key101 and bump not so easy to move rpm limit in that bin so i will test your evc decoder some day and see
  2. #32
    Apr 2013
    I got the program to work, but dont know any code
  3. #33
    Nov 2012
    For old Key101 you can read right trho it if you hawe a labtool 48 for exampel just use Low wolt "chip driver"
    old Superchip has diffret type that i dont know
  4. #34
    Apr 2013
    cant get the winkey to work it only shutsdown ? what do i do wrong?
  5. #35
    Apr 2013
    oki got it to work but it dosent scramble the bin back to normal
  6. #36
    Apr 2014
    I got in my hands a marelli 1av ecu that has a plcc32 27c512 eprom. Basically it has a EVC 512 key. Its a converted unit from autotest that has a internal map sensor for boost applications.
    I am reading the eprom and the file is a mess...
    Do you have any ideas how i will sort this problem?
  7. #37
    Nov 2012
    smartville in front of a OBDplug
    the board are the boards
    then each tuner has his own coding
    otherwise his competitor ca see the files uncrypted it should have no sence ....
    all this board have anyway no sense since the processor from the ecu read the map ....
    and so you can also read the map ;-D just by loging
  8. #38
    bobolin4o's Avatar
    Bulgaria, V. Tarnovo
    Why the hell you want to read someone else job? There is not any big secret in tuning maps.
    Just remove this crypto board, program chip with appropriate software and go ahead... Or if you have some doubts about your skills, take a spare ECU and play with it.
  9. The Following User Says Thank You to bobolin4o For This Useful Post:
    J_amb_o (28th August, 2014)
  10. #39
    Jun 2012
    Quote Originally Posted by bobolin4o View Post
    Could be a thousand reasons you would like to decrypt a chip. I helped an Alfista who had a scrambled chip in his track day car. It was a M2.10.3 ECU with a PLCC32 socket. In that socket was an adapter to DIL28. In the adapter was the protection board, and in the protection board the EEPROM. He had huge problems with the car cutting out randomly. I replaced the awful stack with a plain unscrambled EEPROM and the car never failed since. (see picture).
    Right now I have in my hands another copy protected EPROM for a 155 Q4 with absolutely no marking on it. The owner would very much like to know what chip this is, who made it etc. Descrambling it is the only way to get any closer to knowing what it is.
  11. #40
    Apr 2014
    These ''made'' ecus are sold 15 years back from autotest. They convert the n/a afh 1.4 16V engine to turbo.
    I want to edit the file, to run with bigger injectors and more boost...
    Back in the day it was probably a secret setup but nowadays its a cheap way to boost this engine...
    I read the file and its a mess....
    I i read the file with a programmer and if i desolder the key and stick it to the programmer complete with the eeprom, am i going to read the file properly?
  12. #41
    Sick world
    Quote Originally Posted by AlexG40 View Post
    Have you finally managed to read the file ?
  13. #42
    Aug 2008
    take out the adapter board with everything on it (maybe also remove the flash chip and just read this) (forgot which needs to be done, its been a few years since i looked at these encrypted files)
    put into a programmer and read
    then post the dump here with has much info about it you can
    ie key101 etc
    also ecu type and what the flash chip was you read ie 27c1024 etc
    also when posting dump make sure you name it encrytped
  14. #43
    Mar 2015
    Hi, got a problem with this Volvo FH12-420 27C512 DIL 28 Encrypted file ... can someone help me understand?
    Encrypted with EVC 101
    TI-27C256DIL-SOLOEPROM-MARCON.zip
    Many Thanks in Adavance
  15. #44
    Dec 2010
    Anyone help with 610 algo?
    MPPS Standalone Master, Magpro Base + X17, Dimsport New Genius, Piasini, Galletto V53, Kess V2, K-Tag, Trasdata remapping tools | OP-COM, VCDS, Fiat MultiECUScan, Ford F Super, Renault CAN Clip V124, INPA/NCS Expert + others.
  16. #45
    Jul 2017
    I just wanted to chime in with my results.
    I was able to read a 28 pin 27C512 that was encrypted and using a Key101 to run a bosch motronic M3.3 in a BMW.
    Using a Universal TL866CS chip reader/programmer and it's supplied software MiniPro v6.5 I got a clean read of the .BIN from the encrypted chip with the Key101 attached. I verified by loading the .BIN read to a chip emulator and the vehicle ran beautifully.
    In the MiniPro software select the 27SF512 chip ID, uncheck the "Erase Before" and "Check ID" options then read...
    Side note; the TL866CS was also able to erase/blank a series of fake SST 27SF512's acquired off Ebay, something my Moates Burn2 couldn't do.
  17. The Following User Says Thank You to Mykk For This Useful Post:
    Brotronic (22nd May, 2024)
