Page 1 of 4 1234 LastLast
Results 1 to 15 of 50
    Jun 2009
    Default How to read coded (copy protection) chips?
    I have an eeprom with extra socket (copy potection from Graau tec) liying on my desk. I read the eeprom seperate and also with socket. I got two different readings.. and of course no one is ok what can I do? Why is ECU able to read from the eeprom and not my eeprom reader?
    Jun 2009
    After more googleing I read about the difference between ECU reading and programmer readings...
    If ECU is reading a single adress from EEPROM it switches CS (chipselect) every time. If I want to read with programmer, chipselect is always set tpo on... This is noticed by the little extra IC on the socket and it returns only crap data...
    So I need to write a skript for my willem Programmer to switch CS after reading an adress... But I dont know how... someone does?
    Default protection on socket
    Hi Michi84, if you can, just out the eprom with the GrauTec protection, put this on your programmer and read it, you can understand that the data in original program must go to the same way....
    no need to past your time in program if you have all ....
    Jun 2009
    Quote Originally Posted by dof View Post
    i did exactly that, but its crypted and trash! I read eeprom and also eeprom with grautec socket.... both are crypted trash. different, but trash
    there is a way to decrypt the eeprom read, but i think its easier to read socket& eeprom with a behavior like ECU....then you get a proper reading..
    Jun 2009
    maybe i was wrong... its not CS its OE output enable.
    Is there a way with a programmer (Willem) to toggle OE after reading a single address?
    Top Poster + v8 dave's Avatar
    Jun 2009
    Geordieland -> Portsmouth
    Don't know enough about it personally, but I'd be very interested to learn. I paid ?745 for a single chip(!) for my 1996 V8 Range Rover, and I'll be blown if I'm going to be stopped from copying it and putting it in my other car (same engine, same EFI system, fitted in a Ford Sierra )
    Junior Member maxtdi's Avatar
    Nov 2010
    Slovakia
    Default Here is EVC protection key decoder
    Included all algorithm from EVC,also used from Dimsport and CMD and many other comp....................
  8. The Following 17 Users Say Thank You to maxtdi For This Useful Post:
    aboutton (1st December, 2017), amishmafia00 (26th September, 2016), Axell85 (8th March, 2023), fivebanger12453 (11th January, 2023), Fool2cool (6th June, 2022), galiza (11th September, 2020), gussone (28th March, 2017), hbalazs (16th February, 2020), keesg60 (22nd March, 2017), LinL (21st June, 2016), LinusLinus (1st December, 2016), martinracing (21st November, 2017), mexanico1971 (28th August, 2014), okm (4th October, 2018), pvl (12th May, 2013), tobygolf66 (8th November, 2013)
    Jun 2009
    So. do we simply read the contents out of the EPROM on the board or through the copy socket?
    How do we know which algo to choose?
  10. #9
    Nov 2010
    Slovakia
    Read only eprom and use for saving file extension -file.key. Copy protection key from EVC,CMD,DIMSPORT.and..and..have algorithm number on board 600_00,500_00,101_00.......
    Then winkey d 600_00 file.key
    Or send me key file, make for you...
  11. #10
    Nov 2010
    Slovakia
    Default here ist picture with algo 101
  12. #11
    Jun 2009
    Thanks! I'll have to play with this!
    Think mine may be key400 though, as it's a PLCC44?
  13. #12
    Nov 2010
    Slovakia
    yes 400 or 410
  14. #13
    Jun 2009
    Is it also for Grautec KSM-DIL28?
    I dont know how to use this soft.. maybe someone can help me.. I attached the coded file which I just read from the eeprom.
    thx
  15. #14
    Nov 2010
    Slovakia
    file????? and car ?????
  16. #15
    Jun 2009
    Quote Originally Posted by maxtdi View Post
    sorry. its vw golf 2 g60
    m27c256b
    I got the program to work, but dont know any code for grautec... but as the write on their HP everybody gets his own unique coding....maybe it doesnt work for their chips...
