Results 1 to 9 of 9
    May 2010
    w.yorkshire
    Default FORD IDS WORKING ON WINDOWS 7
    anyone who read my thread about failing to connect to transits will know i have had probs with ids
    http://www.digital-kaos.co.uk/forums...roblem-167149/
    i decided to try it on windows 7 ultimate and it installed fine..run fine..and cable drivers installed fine so i went out to try on a mondeo i have and all functions seem to work ok. i will be trying it on a transit tomorrow to see if it overcomes my probs. if not it would still be fair to assume if you have windows 7 ultimate you can run ids on it and the problems i am having are mine alone. anyone trying it please post result for others. also i have not tried win 7 NON ULTIMATE so maybe it is only ultimate that will work. i also DIDN'T need to choose xp in compatability mode, regards steve
    Aug 2010
    Looking fwd to the info. I will try to find a transit to connect to this week.
    May 2010
    w.yorkshire
    transit same prob so maybe my vcm is at fault. spoke to seller and will be checking settings before exchange. glad i bought from uk seller. still shows win 7 should be ok for who uses it, regards steve
    Dec 2008
    Default win7
    hi i am a win7 user on a new laptop i find connecting striaght forward and uptil now hazzle free,except on peugeot, and vauxhall.
    audi, bmw, merc beautiful, but never tried a tranist, where as using xp was daunting, maybe because the laptop was too old, interesting point you make looking forward to your comments.. i will try and find out if someone has a tranny an give it a try....thanks
    May 2010
    w.yorkshire
    thanks the thread was just to refer to ford ids dealer software. just an update on a 2000 2.0 i was able to connect manually choosing 2.4...and on a 55 plate new shape (square headlight) it connected automatically and worked well. so my problem seems to be on 2001-2004. can anyone suggest a reason or are these years different protocol or pins on dlc??? thanks steve
    Jun 2010
    Thanks , this was really helpful.
    Nov 2010
    yes i think
    May 2010
    w.yorkshire
    ok, the error i get is testman error 12 56 214383. this error comes up when trying automatic connection.
    does anyone know what this error code means and how to resolve it? thanks steve
    Nov 2009
    Staffs UK
    It may be a coincidence but I have noticed that e-TIS requires a PCM calibration update on the early Transit vans in order to carry out speed limiter setting etc or maybe your transit is acting up
