Page 3 of 13 FirstFirst 12345678 ... LastLast
Results 31 to 45 of 186
  1. #31
    Jul 2016
    hello guys I wanted to ask if you can do this thing.I have astra h 2004 display gid + CD30 mp3 blaupunkt. I bought new Delphi radio grundig CD30 MP3 aux. my question and if I copy dump blaupunkt with original code and then I copy dump grundig anyone can enter codes in the original CD30 grundig? and can this thing? thanks in advance
  2. #32
    KierAn20's Avatar
    UK
    Quote Originally Posted by salvax16 View Post
    Yes but would need your display dump also to make the correct pairing data.
  3. #33
    Newbie Teledani's Avatar
    Jul 2018
    Spain
    Default CD60 Navi
    Hello
    I need the code and VIN from this dump file please. CD60 Navi (i think 24c32)
    I buy this radio on eBay but it's not divorced.
    Thanks.
  4. #34
    WALES
    Quote Originally Posted by Teledani View Post
    Hello
    Thanks.
    Your code is 5885
    wbr
  5. #35
    Hello
    Ineed code forom radio opel corsa CD30 MP3 Delphi memory 24c32.
    serial 13466748 497 316 088 2012r.
    Thanks..........
  6. #36
    WALES
    Quote Originally Posted by zdzicho1233 View Post
    Hello
    Thanks..........
    Pin is 3119 but for pairing you need Display Pin
    wbr
  7. The Following 2 Users Say Thank You to shooting For This Useful Post:
    irfa (19th July, 2018), zdzicho1233 (19th July, 2018)
  8. #37
    irfa's Avatar
    Feb 2016
    Hello
    Thanks..........
    code is 3119
  9. The Following User Says Thank You to irfa For This Useful Post:
  10. #38
    WALES
    Hello
    Thanks..........
    Here is your dump unregistered .. for correct PIN post display dump
    wbr
  11. The Following 3 Users Say Thank You to shooting For This Useful Post:
    bogege (19th July, 2018), irfa (19th July, 2018), zdzicho1233 (2nd August, 2018)
  12. #39
    Jul 2018
    Spain
    Thanks, but, last thuesday I went to my official Opel dealer for radio coding and they told me that they can't enter this code.
    Please, could you confirnme that the code is correct?
    The radio is paired with an other car, if it is posible, could you post an unregistered dump? I think that if I reprogram the radio with an unregistered dump it will be easier work for the Opel guys.
    Thanks again.
  13. #40
    WALES
    Thanks again.
    post dump from display for code
    wbr
    Here is your CD60 unregistered:
  14. #41
    Jul 2018
    Spain
    Thanks shooting, tomorrow I will program the radio with your dump.
    Is it needed the dump from the display?
    Anyway, I post it.
    Let me explain something about it. The original code from my car is 8680 but I am afraid that I have changed it in the display and the bluetooth module. I tried to pair the CD60 with Op-COM and an option that said "Activate antithef security without radio" and I entered the 5885 code. It does't work, but after that, I can't disable the antithef using 8680 or 5885, and can't pair the CD30. Maybe it is just an Op-COM limitation.
    My Opel dealer told me that 8680 (original code) worked for him, and he could enter into DIS without problem to try programing the CD60.
    What do you think?
  15. #42
    WALES
    Anyway, I post it.
    What do you think?
    Here display repaired, pair using 8680 using this display dump
    wbr
  16. #43
    Jul 2018
    Spain
    I tried to program the display with a modded dump by me just like yours! Changing 35 38 38 35 to 30 38 36 38. The display entered in delivery mode, showing intermittent "display safe". If I fisicaly disconnect the bluetooth module, I could pair the CD30 and the display again using 8680, but when I connect again the bluetooth module it show permanet "UHP safe". If I don't fisicaly disconnect the bluetooth module I can't pair both, display and CD30, so I think that UHP has 5885 code inside.
    I disambled it to make a dump of the eeprom and try to make the same process with the display, but I can't find any 25xxx eeprom. In other forum I read that making an update of the UHP will reset it and could by coded again.
    What do you think? Or how should I proceed?
    Thanks for your time!
  17. #44
    WALES
    So 5885 is in the UHP? if so don't use my dump but pair using my radio unreg and use 5885
    wbr
  18. #45
    Jul 2018
    Spain
    Yes, I think so. As you can see, the display has 5885 inside and right now, the display and the UHP are paired. So, by force, the UHP must have 5885 inside. I think that the code changed in both when I tried execute "activate antitheft security without radio" with 5885.
    The rest of the modules are untouched, or I think so, because the immobilizer still use 8680.
    I'm going to reprogram the CD60 with your dump, go Opel, and let you know what happen xD.
