Page 2 of 2 FirstFirst 12
Results 16 to 23 of 23
  1. #16
    Aug 2009
    too many fixes,..too many troubles!
    Its not blacklisted mux,..its shown that your mux type is not allowed.
    erase xentry,..and start again from beginning,...cool down,..and check your fixes!
  2. #17
    Feb 2010
    Ok I have installed Xentry new 2 times but only Xentry should I install it completly new? (Windows DAS WIS Xentry?)
    I applied the DAS patches and the 2 patches from Zolookas
  3. #18
    Feb 2010
    So I tested again today completly new installation, but I get the same error msg.
    What can I do? Do anyone have an idea?
    I solved the problem now Xentry 09/2010 had an error. I installed 05/2010 and everything is fine now
  4. #19
    Jan 2010
    US
    Quote Originally Posted by mtu2u View Post
    From 07/2010 Xentry has blacklist inside the programm itself.
    Build in. That's why 05/2010 works.
    What goes around , comes around ..
    If I was helpfull click "THANKS" .
  5. #20
    DK Veteran gmatj's Avatar
    Dec 2009
    Heaven (is place on earth)
    Quote Originally Posted by fobara View Post
    Wrong statetement same result though.
    "inside the programm itself. Build in"
    The truth is that the blacklist for Xentry is in another place !! (DAS and Xentry have got different blacklist files)
  6. #21
    Dec 2010
    mu2u hi can u tell me pls also coz i have same problem pls pls
    thanks Advance
  7. #22
    Junior Member Dreamer001's Avatar
    May 2010
    mtu2u You have to reinstall Xentry. You are missing files...
  8. #23
    Sep 2009
    Quote Originally Posted by Patrian View Post
    IF you search little "Harder" on the Forum, i think you will found the Solution...
    Good Luck!
    Hi m8s! Pat , show the way !! Please.
    Every day, every hour I like. Still alive.
