Page 2 of 2 FirstFirst 12
Results 16 to 24 of 24
  1. #16
    Quote Originally Posted by momo201 View Post
    salu verifait tres bien tes fil sur le moteur asur toi aven de passe a l'uce ok
    Its means: Hi, make sure that the cables and connections are safe on the engine before thinking to the ECU
  2. #17
    Nov 2010
    Quote Originally Posted by charly_joe View Post
    Hi - I tried this tonight, first with the BSI, I went to Download>BSI>Downloading of a new software version > connect to internet (no) then it tries to update and says "communication error" the ECU HDC (connector next to steering wheel) has not responded. Validate to continue.
    Anyone seen this before?
    Hi All - still really struggling to get this car to start. Can anyone offer any further advice / assistance?
    cheers
  3. #18
    Nov 2010
    I have found the problem. The fuse for the steering wheel switch module had blown and as the car is VAN bus was preventing the BSI talking to the ECU. The car is now starting 1st time and I am absolutely delighted.
    Thanks to everyone for help / suggestions.
    I now need to clear the crash data from the Airbag module.
    Can anyone please tell me how I go about this?
    Cheers
  4. #19
    calin_bm's Avatar
    near civilization
    read eeprom from airbag ecu and post here details
    in some older post,you mentioned something about :"connector next to steering"...what is that about?
  5. #20
    Nov 2010
    Quote Originally Posted by calin_bm View Post
    Hi - thanks for response. How do I read just the Airbag ECU module and not the whole ECU? what hardware / software do I use for this please? PP2000 or Galleto?
    The connectopr next to steering wheel,i think the software was just saying it had a communication issue with the OBD diagnostic port. This was because the fuse had blown for the switch module around the steering wheel which houses the indicator stalks etc so was preventing the BSI communicationg with the ECU as there was a break in chain...
  6. #21
    cool! first you have to see if the cut-off switch is not activated
    is a red button that is in the engine compartment on the passenger side
    Hold down the button and good luck
  7. #22
    Top Poster + Kanaan's Avatar
    in my car
    did you make a scan to the ecu and bsi to look for DTC's
    try so look for a live data to see if the ecu is locked or not .
    God does not play dice with the universe . (Einstein)
    if anything can go wrong it will . (Morphy laws)
  8. #23
    Oct 2010
    hay my frind giv my damp 207hdi 1.6 thnaks
  9. #24
    in my car
    Quote Originally Posted by jazouli_diagauto View Post
    Please open your own new thread for your request !!
