Results 1 to 12 of 12
    Nov 2010
    Default VCT2000 scanner and Volvo DICE 2010 scanner ?
    Could anybody tell me the difference between the VCT2000 scanner and Volvo DICE 2010 scanner ?
    Vct2000 only works on older volvo, dice works on the newer ones. Since volvo vida 2010b the vct2000 interface is not supported anymore.
    Top Poster + Iroll's Avatar
    Default Hi,
    VCT2000 -2010
    DiCE 2011-
    2010A : J2534 and Dice, last version to use VCT2000
    2010B-: J2534 and Dice
    Vehicle communication is based on J2534. J2534 is an interface common to all
    vehicles for reprogramming control modules that can be connected to many
    vehicles. There are two different versions of J2534.
    ? J2534-1 can be used to download software to vehicles from, and
    including, model year 2004. J2534-1 manages software to control
    modules on CAN HS (controller area network high speed) that are emission
    related. J2534-1 cannot be used for diagnostics.
    ? J2534-2 manages software download to control modules on both CAN
    HS (controller area network high speed) and CAN MS (controller area
    network middle speed).
    The hardware used to validate VIDA's compliance with J2534 can be purchased
    separately from third-party suppliers. The validation was done using the following
    J2534 pass-thru devices:
    ? J2534-1: Actia Passthru+ XS and CarDAQ2534
    ? J2534-2: CarDAQ Plus
    I have not used a J2534 pass-thru, let us know how it works!
    Iroll
    Please! Use the ?Thanks Button?
  4. The Following User Says Thank You to Iroll For This Useful Post:
    WENKAT (24th November, 2014)
    Iroll...volvo...Good info. Is there a way to update the actia xs units to 2534-2 protocol..or is it done with the latest drivers? Still fuzzy on this stuff...
    Kind Regards, and remember > Any information provided is for educational/experimental purposes only.
    Default Hi,
    I have no idea?
    Let us know what you find out.
    I have called Actia Support Line today. I asked If Passthru XS covers J2534-2 . He said yes with the latest driver 2.07 does cover it but his voice was not so convincing.
    Jan 2011
    Hi, I have Volvo Vida 2010D software which works fine, I have also Vct2000 hardware, but do you know how to change or add vct2000 to vida when checking on vida it says no communication tool selected? Do I need additional software to add communictions?
    May 2011
    Illinos
    the function of connection to the car is different, VCT2000 use the series interface, Volvo DICE use the usb or bluetooth interface.
  10. #9
    Quote Originally Posted by easyobd View Post
    Read Irolls post above.
    You cannot use VCT2000 with Vida 2010D.
    There is no easy or practial way of adding VCT2000 support to newer Vida versions.
  11. #10
    I wonder whether the Clone version VCT2000 or VIDA DICE could reprogramming ECU,ECM ? or key learning ?
  12. #11
    Clone dice ?does not? work for software flashes.
  13. #12
    Member VolvoGeely's Avatar
    Apr 2011
    Quote Originally Posted by Iroll View Post
    Or a VCT2000 .
    Only Dice from 200000 and later Serial # .
    Every dice serial# plus purchasing login , and the VIN is all recorded on the conformation file sent to the PIE server ,AFTER all is correct .
    The Security drivers for 2011 D has changed .
    VG
