Results 1 to 15 of 26
Hybrid View
    Feb 2010
    Lithuania
    Hi to all, with your help I found immobox....
    so I uploaded new zip file in my first post with ecu, immo and new key data....
    Please help to solve that problem...
    But if I try to program with peugeot planet as P107 I think it will ask for pin like all peug and citroen have ???
    I have T300, SBB and AUTOBOSS for programming key also peugeot planet
    Nov 2009
    Quote Originally Posted by darius89 View Post
    good you found the immo box
    i've not done aygo but have done loads of 107/c1
    you don't need a pin because it's toyota system
    you need virgin file for immo
    when you program with planet/lexia it asks if you have fitted new immo box
    you can program only one key if you want
    have a look on your sbb because my v32.2 says it does psa aygo/107/c1 but i haven't tried it yet as i always use planet etc
    i have the virgin file for the immo box let me know if you want it
    on the sbb go to toyota psa and try it. it gives aygo/107/c1/yaris
