Anybody have files (calibrations) for DDEC V to install in DRS 6 ? Thanks for sharing !![]()
rexelment (6th June, 2024)
06R0810415
06R0795570
06R0807355
06R0734321
06R0812379
06R0858298
06R0858345
06R0790377
06R0799568
06R0833576
06R0800025
you may need to upgrade to a newer version of drs depending on which one you have, so i have included drs 6.16
just extract folder to c:\detroit diesel and copy/merge/overwright files as needed.
when you run drs it will tell you it is being upgraded and shut back down, this is just giving you the new server updates to install new ecm versions. Click program, if truck does not have a matching serial to whats on you list, it will let you select from a list what you want to program and you should see all serials you listed plus 06R1999999. this is the turbo actuator program for use with dddl 6.44 and higher. save all accumulated data before programming. as it might loose all accumulated data during reprogram.
12V92TAB (18th January, 2019), 4hillbilly (15th February, 2014), AdrianCR (2nd November, 2023), AMBSOLUTIONS (9th May, 2020), amosquedat (1st September, 2020), autotec2 (7th August, 2016), bullseyemods (17th April, 2013), deez (30th January, 2015), Diseal tech (15th July, 2013), djz4248 (2nd September, 2013), DK007 (9th April, 2014), donniemnemonic (25th June, 2013), dredo07 (11th February, 2022), Edrenan1 (20th June, 2013), Elfer (22nd November, 2013), harobaua (8th March, 2014), hieu1987 (20th September, 2013), hrobertdm (17th September, 2013), hugos31 (14th April, 2013), Israel07 (22nd August, 2014), jakec94 (2nd April, 2019), juan79 (29th April, 2014), koper (16th December, 2023), kotok008 (1st June, 2021), kwagga (4th May, 2013), leva (6th August, 2023), mang5087 (10th June, 2013), matt75 (8th October, 2020), melgarejo.salomon (23rd July, 2015), mentos (17th April, 2024), mmfix (16th February, 2024), northplains (24th February, 2014), oldwest1971 (29th October, 2023), otoy (20th July, 2016), Poptest (16th September, 2013), RobSher2016 (9th September, 2017), Thatguy1999 (17th April, 2015), TjGill (7th February, 2023), topitopi (7th April, 2014), toshor (4th August, 2013), truckinspector (19th January, 2014)
I got it going thanks
so i take it all worked correctly?
how do we import cal files into drs?
I can't get drs 6.16 work on win 7, I'll try on winxp.![]()
for those of you using the drssec.dll fix, do not use that, that is an old parallel crack and does not work with this version. go to a topic that states ddrs help, i have posted a link to sentinelkeyw.dll, copy and replace. that is a usb engineer crack.
her is thread : http://www.digital-kaos.co.uk/forums...50/index3.html
working on xp for me
Thank you very much ! Everything is fine now Working in both winxp and win7. Great job !![]()
thank you sooo much buddy, working fine on xp sp3....![]()
