Results 1 to 2 of 2
Thread: vag fault code
    Jun 2010
    here
    Default vag fault code
    how men that code p1617.p1550
    Dec 2009
    Quote Originally Posted by smt View Post
    17958/P1550/005456 - Boost Pressure Controle Valve (N75): Control Deviation
    Possible Symptoms
    • Irregular behaviour
    • Reduced power output
    • Limp mode
    Possible Causes
    • Hoses/Pipes incorrect connected, disconnected, blocked or leaking
    • Charger Pressure Control defective
      • Solenoid Valve for Boost Pressure Control (N75) defective
    • Turbocharger defective
    Possible Solutions
    • Check Hoses/Pipes to/between Components
    • Check Charge Pressure Control
      • Check Solenoid Valve for Boost Pressure Control (N75)
    • Check turbocharger
