Results 1 to 5 of 5
    Sep 2010
    Spain
    Default Problem Delco delphi Corsa 9353469
    The Delphi Delco DJTT 9353469 (Corsa Z14XE 2001), don?t work.
    Any solution?
    DK Veteran tomaszcz's Avatar
    ZGP
    Quote Originally Posted by pedrodiaz View Post
    Any solution?
    Hi.
    What is the problem?
    Sep 2010
    Spain
    Quote Originally Posted by tomaszcz View Post
    Hi.
    The car not start, not detect
    Eu
    First check the wiring to the ECU and if this is OK then the problem is in the ecu.
    It is a common Fault, the engine starts sometimes or not at all, and Diagnostic shows the pump valve error.
    The ECU is damaged inside. uy new one, or repair this one.
    I have repaired several now. i can do it for you
